Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-21-2008, 03:04 PM
94mustanggt 94mustanggt is offline
Power Problems
I have a 94 Mustang GT and im having problems w/ my car starting. When i turn my key over there is no power not even accessories but i can jump my car and it will crank over fine. But in 5 mins it will die and i wont have any power again.
Thanks
Alex
Old 10-31-2008, 08:40 PM
K5Calamity's Avatar
K5Calamity K5Calamity is offline
Re: Power Problems
Sounds like a dead battery to me, or you have some corroded battery cables. Make sure your alternator is charging also.
Old 11-02-2008, 02:09 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Power Problems
If the battery light is coming on after you start it the problem is the alternator isn't charging. If you aren't getting a battery light up after starting the problem is probably 2 or more plates shorting out due to sediment build up in the case. If the battery is older than 5 years replace it. It's on it's wat out.
