Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-21-2008, 12:58 PM
Mr. Meaty Mr. Meaty is offline
Heater Temperature Issue
I have a 1995 Jeep Grand Cherokee Limited and the heater temperature is acting up. I need to run the temp control at 80+ to get heat to stay on. Anywhere below, and it blows hot air for a bit and then starts to blow cool air.
Since it's getting colder, I'd like to get on this now.
Is there a temp sensor in the heater controls that I could check/replace?
Since I'm getting hot air, I assume it's not the radiator thermostat.
HAs anyone experienced this problem?
Old 10-22-2008, 06:27 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Heater Temperature Issue
If you have ATC (digital controls) which it sounds like you do. There is a Ambient Temp Sensor for the interior,if you look right above the VIC you will see some vents cut into the dash look like there maybe a little speaker, Behind this the is a tube which takes air to the temp sensor and it adjusts air temp as needed. When you have you heat on (below 80) is the A/C indicator (snowflake) illuminated, trying turning the A/C off and maybe it won't switch to cold air.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 10-22-2008, 10:17 AM
Thanks, I'll check tonight for the vents. The A/C indicator comes on with the heat, but it doesn't seem to make a difference when I shut it (A/C) off.
Since I do get heat, my assumption is that there's a sensor that is not picking up the right interior temp, so you're suggestion sounds good.
I'll update if I can get it working right. Otherwise, my wife might just have to run it on HI all winter.
Old 11-10-2008, 03:12 PM
So, I've resolved the issue. A cell phone cradle was blocking the ambient temperature sensor. Removed it and no more problems with the heat.
Thanks!
