Old 10-21-2008, 12:12 AM
legend1011's Avatar
legend1011 legend1011 is offline
Horrible gas mileage... Any ideas...
My cars getting about 30 MPG... I know that that is good, but I was getting close to 40 before I did a ton of maintenace to my car...
I did the following:
Change brakes
Change Distributer cap and Rotor
Change Spark Plugs
Change Oil
Change Timing Belt/Water Pump
Change PCV Valve
Change Air Filter
New Thermostat and Radiator
New Oil pan gasket
New Valve Cover Gasket
Not sure why my car dropped so much in gas mileage
Any ideas? I'm going to replace the clutch in a week cause the car is slipping a bit (was before) and hoping this will help, but I'm stumped on why it decreased so much.. .
I probably shouldn't have done so much maintenace at once... LOL
Old 10-21-2008, 07:07 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Horrible gas mileage... Any ideas...
I wish mine was getting 30 mpg, I'm lucky if I hit 28, most of the time its 25.
Check to see if your IAT and O2 Sensor are still good. You should get a CEL from them, but that doesn't always mean anything if you don't.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-21-2008, 12:16 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Also the new brakes may need to wear in. Brakes can actually lose you horsepower and cause drag till they are good and worn.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-21-2008, 12:17 PM
FrodoGT's Avatar
Then again, I get 30-32 mpg right now, and always have..
Current project:
Rio Red 91 hatch.
Old 10-21-2008, 02:47 PM
legend1011's Avatar
I forgot to mention. I did replace the O2 sensor as well. I wasn't throwing a code, but I figured since the car has 202,000 miles on it to replace it since it was stock...
I just filled up today and got 33.8 MPG... Perhaps some things need to be worn in...
I'm going to triple check my exhaust cause I know I have a leak (well I have had one for quite some time)...
Will replace Clutch this Sunday and get all the Exhaust Leaks fixed then I should be good for a while hopefully...
I was getting close to 40 though so I I will give it another fill-up and see what happens unless there is anything else....
