Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-20-2008, 07:51 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
02 Montana Vacuum Lines
I have a 2002 Pontiac Montana. When I have the button pushed to bring in fresh air from outside there is a moaning sound inside the dash on the passenger side. Sounds like a vacuum line may be the problem, maybe not enough vacuum to move the door over to pull in fresh air. My problem is that I can't find where the vacuum line runs. Please help. Thanks
Old 10-20-2008, 08:04 PM
Scrapper Scrapper is offline
AF Premium User
Re: 02 Montana Vacuum Lines
try to take your glove box out it's just screw and see if you look down and see hose not conected.
good luck...
Old 10-20-2008, 08:46 PM
While replacing the relay to allow the fan to run on high speed (speed 5), I looked around but did not see anything disconnected. So where exactly should I look once I have the glove box removed? Thanks for the help.
Old 10-20-2008, 08:51 PM
AF Premium User
look for vaccum hose off anywhere and see if that door in there is opening or staying close when you turn on heat or air it don't make a diffirence eather way.
Old 10-20-2008, 09:03 PM
Can anyone else help with a little more specific details? Thanks
Old 10-24-2008, 12:26 PM
rockwood84 rockwood84 is offline
could be a cracked vacumn line or the blend door not moving properly. line and actuator not hard to find and fix but blend door is on the inside of the housing.what you are looking for is a small plastic line that runs to the actuator this is under the glove box and bump cover under the glove box
Old 11-08-2008, 09:59 PM
Still looking for the vacuum. Does anyone know where it goes through the firewall and where it connects under the hood? Again, I appreciate your help.
Old 11-08-2008, 10:21 PM
AF Premium User
i think you should go to auto zone or advanced and get a haynes manual for your car if your going to keep the car so you will need it later. around here they'll let you look at the book or they will show you on computer where it is.good luck....scrapper1.....
