Old 10-20-2008, 12:52 PM
userpete1037 userpete1037 is offline
Pitman Arm
I own a 95 Chevy 1500, 2WD 350 and it has a shimmy in the front. All the bushings and balljoints have been replaced even the wheel bearings. I noticed that there is about a 1/2 inch gap between the pitman arm and the steering housing where it is mounted. Is that the reason for the shimmy?
Old 10-20-2008, 01:14 PM
2000CAYukon 2000CAYukon is offline
Re: Pitman Arm
The pitman arm is pressed on so it will not touch the steering house. Can you move it at all by hand? Does it move up and down when someone turns the wheel?
//2000CAYukon
Old 10-20-2008, 01:24 PM
j cAT j cAT is offline
Re: Pitman Arm
with all the work done on the steering componets was this created by this replacement or you had a shimmy and just threw some parts at it!???
shimmy is for me a bad out of round tire ...seen this many times...If this occurs at some specific speeds the wheel weight fell off...
on very rare occations it may be the brake rotor...
If the pitman and idler arms are worn you will get wondering and possible shakes when going over a bump...
Old 10-20-2008, 07:38 PM
Re: Pitman Arm
I think it's more to do with me needing new tires. It actually drove better when I put some more air in the tires because the pressure was very low. I just happen to notice that about the pitman arm and I was curious if that should be that way.
Old 10-21-2008, 10:06 AM
Re: Pitman Arm
when you increase the tire pressure defects if any in the tire will cause you to feel it more.
uneven wear,out of round, belt damage...also the work just done must include a wheel algnment..
the pitman idler arms should not move more than 1/8 inch up and down at the joint...
Old 10-21-2008, 10:22 AM
123456321 123456321 is offline
Re: Pitman Arm
sound proofing material for cars can be found at
http://noisekiller.se/
Matériel d'insonorisation
Old 10-22-2008, 04:08 PM
Re: Pitman Arm
I replaced the balljoints, upper control arm bushings months ago and had it all aligned afterwards so I'm quite that has nothing to do with it. I think it may be just bad tires. Like I said, I just happen to notice that about the pitman arm and just had to ask if that's how it's supposed to be because I've really never paid attention to it.
