Old 10-20-2008, 10:47 AM
ttinsleyjr ttinsleyjr is offline
White Smoke
I got my fuel filter replaced a few weeks ago because I was having some starting issues. I also had my Intake gasket replaced a couple of days back now whenever I start the car (3.8, 98) I get a small cloud of white smoke. What could this possibly be?
Old 10-20-2008, 12:21 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: White Smoke
White smoke is caused from burning coolant.
Sounds like your intake gasket job perhaps didnt get done properly?
What all was done? Were the lower gaskets changed as well or just the upper gaskets? What about the upper manifold itself?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 10-20-2008, 01:27 PM
tmartin000 tmartin000 is offline
Re: White Smoke
White smoke--I mean REALLY white smoke, is definetly brning coolant.
Sorry for the bad news.
2006 Pontiac Montana
Old 10-20-2008, 06:25 PM
Re: White Smoke
Thanks for the fast reply...
Upper, lower gaskets, and manifold were replace. It isnt a lot of smoke, its just seems like everything should be fine. I dont see anything leaking on the outside of the manifold though...
Old 10-20-2008, 06:50 PM
harmankardon35 harmankardon35 is offline
Re: White Smoke
usually you would smell coolant burning out the exhaust, that classic sweet smell...but i have no idea if dexcool has the same characteristic odor when burned. Dont mistake it for steam if its a wet or humid/cool day....bring the car in and have them pressureize the system and check for leaks, sldo keep an eye on the coolant level....
Old 10-20-2008, 07:34 PM
Re: White Smoke
Thanks for the advice... Yeah its been pretty cool here in cleveland. I'll take it in and keep you guys updated...
Old 10-20-2008, 09:37 PM
dtownfb dtownfb is offline
Re: White Smoke
I have a similar situation developing on my 2000 Intrigue (3.5L). Every once in a while at startup i get a big puff of white smoke out the exhaust. My mechanic thinks it could be the begining of head gasket leak. I have to add coolant once every 2-3 months.
Old 10-21-2008, 06:23 AM
Jimmy Olsen Jimmy Olsen is offline
Re: White Smoke
Bar's Leak is a damn good fix. My pick-up was really sucking in coolant and it fixed it.
1995 Dodge Ram 1500, 143k miles
1999 Oldsmobile Intrigue, 121k miles
2006 Subaru Forester, 68k miles
Old 10-21-2008, 03:19 PM
Re: White Smoke
while most people wouldn't usually recommend additives, I have heard that GM puts a bottle of 'bars leaks' in every vehicle with an aluminum engine when its made. Im not sure if this is 100% true but Ive heard that from many mechanics...Theres an aluminum powder kind of sealer that you should avoid at all costs...it tends to plug up the system.
Old 10-27-2008, 08:16 PM
Re: White Smoke
So Ive taken my intrigue to a mechanic and after a week its not coolant its burning but OIL!!!
What could this possibly be and what steps would you guys suggest for troubleshooting?
Old 10-30-2008, 08:10 PM
Smile Re: White Smoke
How much oil?
Old 10-30-2008, 09:31 PM
Re: White Smoke
about a quart every 3 weeks
Old 10-31-2008, 12:50 AM
Re: White Smoke
a quart every 3 weeks isn't a hell of a lot to worry about...I have had cars that burnt a lot worse. Change the oil as often as you should, try a slightly heavier oil (maybe a 5/10w40 instead of a w30) Also, someone should chime in but does a stuck PCV valve contribute to oil burning?
Old 10-31-2008, 06:26 AM
Hoppy2 Hoppy2 is offline
Re: White Smoke
It could not hurt to change the PCV. Typically if they rattle when shaken they are ok, but are cheap enough to change to see if it is your problem.
Old 10-31-2008, 10:51 AM
Re: White Smoke
You have a point. Could the pcv valve have anything to do with the egr valve?
