Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-20-2008, 10:42 AM
ringfinger ringfinger is offline
"Service Engine Soon" Light Problems
2002 Saturn SL1
81k Miles
No previous problems until this light came on.
I had the light diagnosed at Auto Zone and it came back with 2 different problems.
IAC circuit condition or idle speed higher/lower than expected.
The ECM has detected that the IAC counts are higher or lower than expected, the engine speed is not in it's expected range.
Probable Causes: Vacuum leak on engine, dirty throttle body, IAC motor defective, poor electrical connection.
I didn't think these cars had an IAC or throttle body since they are fuel injected. Anyways, I haven't noticed anything strange about the idle. The cars runs smooth.
Coolant temp is always low.
Probable Causes: check coolant level, thermostat defective, ECT sensor defective.
The coolant did seem low. The engine was warm when I checked and the level was at the lowest allowed cold engine level, so I added some.
I also checked the oil and it took about 1.5 quart to get back up in the full range.
I then disconnected the battery for 15 minutes, reconnected, and haven't seen the light again yet.
Everything seem ok?
Old 10-20-2008, 05:01 PM
RC1488 RC1488 is offline
Re: "Service Engine Soon" Light Problems
#1 : Bad intake manifold gasket. Notorious for 3rd gen SOHC s-series. Spray brake cleaner near the intake gasket around each cylinder especially cyl #1. You will notice a change in the idle---> proves the gasket is leaking. Search here for a How-to with pictures...Quite an easy job that can be done saturday afternoon.
#2 : Add more coolant! Which you did so you should be good to go. Normal operating temps for your car are 1-2mm above 1/4 as per the gauge
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
