Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-19-2008, 10:54 PM
Irishdog Irishdog is offline
MAF question
I have a 1992 eagle talon n/t 4g63. I want to get rid of the 1g MAF, but I am uncertain as to what path I should take in doing so. Which setup would be a better for my car? (daily driver) The 2g MAF swap with the AFC, or the GM MAF with the MAF translator? Thanks for the input in advance.
Old 10-20-2008, 06:16 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: MAF question
Why would you want to get rid of the 1g maf?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-20-2008, 07:53 AM
Re: MAF question
Just trying to get better air flow because I don't see how air flow can be at its apex if the MAF is crammed into the filter. Using the 2g MAF or the GM MAF would put the unit after the filter allowing for better air flow. Is this not correct?
Old 10-20-2008, 08:09 AM
Holset powered 420a
Re: MAF question
You may get a little bit more flow but I wouldn't think its worth the headache of trying to get the GM maf to work correctly. After all the car is NA and the gains would be minimal. If a 2g maf is plug and play then it may be worth it but I still dont think you will see much power.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-20-2008, 08:48 AM
Re: MAF question
the 2g has to have a wiring harness fabricated for it, which isn't hard at all. But there are mixed opinions about using it with an AFC and 550 injectors if one of those compensates for the other. I'm not really looking for power gain just a cleaner compartment and a better unit to work with. What problems would I face using the GM MAF if I have the MAFT hooked up to it?
Old 10-20-2008, 11:59 AM
Holset powered 420a
Re: MAF question
Why the hell are you using 550 injectors on a NA car? I think I saw on tuners you plan to go turbo soon? Not sure if that was you or not. But the GM maf some people have problems getting everything to work properly. I dont use a maf so Im not sure about the translator and all that crap but I have heard many people having problems with it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-20-2008, 01:32 PM
Re: MAF question
I'm not using 550 injectors nor am I going to. That was for turbo application. How did you get by without a MAF?
Old 10-20-2008, 01:45 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: MAF question
Silvr has a 420a motor that doesn't have a MAF. Only a MAP sensor.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-20-2008, 02:59 PM
Re: MAF question
Ok, thats what I figured, but just making sure. I just know that the 1g to 2g MAF was a common upgrade, but was wondering if swapping to the GM MAF with the MAFT would be a better way to go. Just didn't want to have to get the AFC in order to make the 2g work on my car.
Old 10-20-2008, 05:39 PM
kittay's Avatar
kittay kittay is offline
Re: MAF question
You do have to consider that by changing out the maf, it'll run way leaner. I wouldn't suggest doing that, esp since you wouldn't have a way to tune for the changes.
12.3 @ 112
12.5 @ 115
Old 10-20-2008, 07:28 PM
Re: MAF question
Ok so I guess I will stick with the 1g MAF. Thanks for help it is much appreciated.
Old 10-20-2008, 08:11 PM
lasersturbo's Avatar
lasersturbo lasersturbo is offline
Re: MAF question
plus if you do a 2g mass u will need a 2g eprom, a 1g eprom will not reconize it and it will make ur check engine light stay on and eat gas, cause the ecm sees that there is no mass sens, not a plug and play option ive done it and seen it
Old 10-21-2008, 12:22 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: MAF question
All wrong, not to mention borderline illegible.
Please do you homework, both here and in English.
Kris
2012 Genesis Coupe 2.0t
Old 10-21-2008, 10:57 PM
Re: MAF question
Old 10-21-2008, 11:19 PM
steviek's Avatar
steviek steviek is offline
Re: MAF question
dude you don't need a 2g ecu to run a 2g mas. Infact you can't run the 2g ecu without changing everything.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
