Go Back   Automotive Forums Car Chat > Honda > RSX
Old 10-19-2008, 05:30 PM
F1FanaticGT3 F1FanaticGT3 is offline
Angry RSX-S Stuck Oil Drain Plug!
I have a 2005 RSX Type-S. Recently I had my oil changed at some local shop in town. I have no freaking clue wtf these morons did, but my only guess is they used a damn air gun to put it back on because it is cemented in there. I have tried everything! Started out with the proper 17mm socket and ratchet then moved to a longer and bigger wrench to get more torque, but nothing. It will not move!!! It is really irritating to say the least. I'm to the point now where I think if I mess with it anymore its going to start rounding out the bolt. Now I thought I read another post here for an Intrigue that said to loosen those drain plugs you had to go the opposite from lefty loosy righty tighty. This is the first time I have changed the oil on this car so maybe I am caught off gaurd. Does anyone have an suggestions? Thanks again in advance!
James
Old 12-19-2008, 02:04 PM
mmont0's Avatar
mmont0 mmont0 is offline
Re: RSX-S Stuck Oil Drain Plug!
Most plugs loosen cc-wise. I think they probably overtightened the bolt. If it's already stripped, then I would take a rotary tool and etch a deep straight line on the bolt head and use a flat screwdriver to see if that takes it off. If not, drilling the bolt would be the last option. Just make sure not to drill on the threads.
Here's something I found at sears - http://www.sears.com/shc/s/p_10153_1...seBVCookie=Yes
Originally Posted by SBallerk2
yeah...I thinking of trading in my '94 Lude VTEC for an RSX-S
Old 12-22-2008, 07:31 PM
3000bolts 3000bolts is offline
go back to the shop and tell them what u think.
Old 01-01-2009, 03:00 PM
kris's Avatar
kris kris is offline
Off playing with fire.
I agree with that one. See if they will remove it for you.
