Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-19-2008, 04:42 PM
macctheknife macctheknife is offline
Question No start problem
Okay heres the deal...thermostat housing was jacked up(plastic intake as we know) replaced entire intake with new one...new plugs as well as new battery...car ran FINE before...will not start now...i was thinking that the camshaft position sensor or crankshaft sensor is bad...also my injector clips are broken so they dont seat properly...dont laugh...zip tied the down nice and snug til i can replace electrical connectors...any thoughts on waht the problem might be?? Thanks for any help i can get!!
Old 10-19-2008, 05:14 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: No start problem
What are you missing? Have you checked for spark and fuel pressure? One will be missing. COuld be as simple as a wire unplugged. Let us know.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-19-2008, 09:41 PM
it has ignition coils...has good fuel pressure...could one of my coils gone bad(or all) had some moisture in the spark plug journal closest to the driver(driver side under the cowl) could that have ruined the coil?
Old 10-19-2008, 09:58 PM
Blown head...nevermind...water and coolant all in my spark plug holes...IM SCREWED
Old 10-20-2008, 08:12 AM
way2old's Avatar
TOKEN HILLBILLY
Are you sure? If you did not drain all the coolant you could have had some run into the plug wells. I had a tech do that and could not figure why the engine missed so bad. Clean out the wells, replace plugs and see if it starts.
Old 10-20-2008, 07:45 PM
i pulled the plugs twice now after cleaning the wells and everytime i pull em there is water/coolant in there...im thinking its the head(but i have been known to be wrong)haha seriously though...if each time it was filled with water/coolant in the wells do you think im correct in thinking the head is blown?? I really appreciate the help!!
Old 10-20-2008, 08:02 PM
rhandwor rhandwor is offline
A radiator shop will do a gas analysis and you can be sure. Use a pressure tester put appx. 10 psi on the gage if the gage pulses its got a blown head gasket. http://www.autopart.com/tools/toolsmain/tool/T_7050.htm
This is a picture of one. Take the heads to a machine shop and have them pressure tested and shaved if needed. Use a flashlight lay it flat along the block and check for cracks. Normally between the cylinders.
Old 10-21-2008, 06:21 PM
i have a pressure tester...just remembered that i have one...thanks for the help...ill let you know wht i find!!
