Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 10-19-2008, 01:22 AM
tlowman tlowman is offline
Sway bar on an '02 Wrangler
I am wondering if the sway bar end link sleeves (mounting holes on the ends of the sway bar) are threaded or not? I was replacing one and the end of the old sway bar end link was seized up in the mounting sleeve. I have started drilling it out, but need to know if I will need to re-tap it (if it is supposed to be threaded) or just drill it large enough for the top mounting bolt of the sway bar end link to fit through. Thanks.
-Tom
Old 10-20-2008, 09:29 AM
tomvid tomvid is offline
Re: Sway bar on an '02 Wrangler
From m recollection, they are not threaded.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
Old 10-30-2008, 11:14 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
negative.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 01-13-2009, 04:47 PM
jpanisiak jpanisiak is offline
I just replaced my sway bar links yesterday on my jeep, and 100% sure they are not threaded whatsoever, just a clean drilled hole through the end of the sway bar.
Old 03-12-2009, 05:49 PM
BLAZERBOY69 BLAZERBOY69 is offline
-Tom
they are not threaded, however, i had to take a torch to mine in order to get the old link off the sway bar. they pretty much weld to each other in the course of drivin around.and if you do use the torch, don't point it toward the fenderwalls (i now have a burn hole on my driver side fenderwall lol)
Old 04-25-2009, 09:48 PM
BoatCop's Avatar
BoatCop BoatCop is offline
It's a press/taper fit.
Go to Auto-Zone and rent* a tie-rod puller. It'll pop right off.
*Rent is free, but you have to leave a deposit, which you'll get back when you return it.
Alan
BoatCop
