Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-18-2008, 08:00 PM
96_blazer_5spd 96_blazer_5spd is offline
99 jetta 1.9 tdi
i just replaced the timig components/waterpump/fuel inector pump. and i am having a problem keeping the engine running. and i can only start it with ether. is this just a case of me timing the pump wrong?
Old 10-23-2008, 06:13 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 99 jetta 1.9 tdi
the pump timing can only be checked with a scan tool with engine running. To adjust turn the engine off and loosen the 4 bolts on the gear and turn the gear (foward to advance) (reverse to retard).
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-13-2008, 09:14 PM
TdiJetta99 TdiJetta99 is offline
There are only three bolts holding the IP gear to the pump, but that doesn't matter.. Also, ether will destroy a TDI in short order. I put a set of rods in one a few months ago due to a few bent ones from an ether overdose. That was one very expensive can of starting fluid, LOL
When you did the timing belt/water pump, did you use the proper lockdown tools for the cam and IP, there's really no way to do it properly without them.. you can get away with a drill bit for the Injection pump, but you really need the cam lock tool..
You also really need a factory type scan tool to check the injection timing.. I use VCDS (used to be called vag-com). It's actually more functional than the facory VW scan tool..
Also I hope you replaced the large roller on the bottom near the water pump. That will be the first thing to fail if it wasn't..
You can get all the parts in one kit from a variety of online vendors that comes with all the 100k parts from the 2003.. Belt, tensioner, all 3 rollers, water pump, one time use bolts, serp belt, etc..
Old 11-16-2008, 08:27 AM
VDUBMAN
www.ecstuning.com is the best site for kits, they even sell the tools.
