Old 10-18-2008, 02:45 PM
dwendt1978's Avatar
dwendt1978 dwendt1978 is offline
Replacing clutch cable
I have a 93 Metro, does anyone have an idea if this is easy to replace?
It's so rusted in the engine bay that I can't adjust the clutch and it needs it bad. It looks like it would be a pain in the neck to disconnect it under the dash!
Old 10-19-2008, 10:30 PM
Torqued Torqued is offline
Re: Replacing clutch cable
I have a 95 and replaced the cable twice so far. Not hard at all. There's a swaged ball on the pedal end that fits into a slot on the upper end of the pedal. Did it by feel but not that hard. I had to remove the bracket on the transmission both times in order to get the adjusting nut started and then it went back on easy. Took about 10 minutes plus adjusting it to feel right.
Old 01-02-2009, 03:03 PM
JetengineMech JetengineMech is offline
I dont know about the cable .. but doing the cluch on a 1994 metro sucks. Just did mine and had to take it down again. after getting it all back together it sliped like it was old. ALL NEW PARTS and it wouldnt work any1 have a clue what could be done to fix this. i took it all back apart again to see if i have missed anything dont think i did but will see good luck with the cable .
Old 01-02-2009, 10:06 PM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
Jetenginemech.
I did the clutch on my 95 last year. You're right, it is a pain. Please start a new thread with your question. It's likely to get missed in this unrelated thread.
Ideas on the top of my head are: Flywheel- Did you check it to see if it was burned out? Oil Leak- Is it possible that you have oil leaking into the clutch. Check the right side of the engine for leaks.
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
