Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 10-18-2008, 02:11 PM
RLDANIEL RLDANIEL is offline
97 Cadillac Steering Problems
Have steering problems. At times steering is very hard, then acts like something breaks loose. Is there a repair or does the steering box have to be replaced? Thanks
Old 10-27-2008, 08:53 AM
lzvbys lzvbys is offline
Re: 97 Cadillac Steering Problems
Maybe your powersteering pump is at fault...A plugged line or a bad pump...
Old 10-27-2008, 01:40 PM
maxwedge maxwedge is offline
A990 racer
There is no way to diagnose this in this environment, as stated a p/s pump pressure test should be performed and also the steering should be inspected for any binding components, belt and tensioner checked for possible slippage.
Old 11-15-2008, 07:36 PM
Back to the steering problem. At idle is when the problem occurs, at higher RPM's the steering is better. I don't have a tester, can they be rented and if so where would I look. What should the pressure be? Thanks Roy
Old 11-16-2008, 08:20 AM
A990 racer
A pump pressure tester set up cost over a 100.00, I would suggest you get a pro to help you with this.
