Old 10-18-2008, 01:23 PM
Lofti1 Lofti1 is offline
Rear Liftgate Strut Support Pins
The upper pins on the rear hatch of my 1998 Windstar broke off due to age and rust. Does anybody have any experience or idea as to how these pins can be replaced to support hte struts?
Old 10-14-2011, 06:55 PM
mtsav8or mtsav8or is offline
Re: Rear Liftgate Strut Support Pins
I just finished fixing this problem on my van. Here's how I did it.
Tools used:
4" Angle Grinder
Regular Drill
Proper size drill bit
Socket Wrench and Sockets
Parts Source:
http://www.autopartsbylou.com/index.phpr
http://www.autopartsbylou.com/lift-s...item=b-bs10-1z
You'll need a 10mm Ball Stud. You'll also need to buy a fitting nut and lock washer.
I used the 4" grinder to grind what was left of the stud flat to the bracket. Then I used a high carbon drill bit about the same size as the stud to bore a hole through bracket where the old stud was. Afterwards, it was just a matter of fastening the ball stud to the bracket and attach a new lift strut.
It looks like the stud will be too big to clear the opening but if just fits and works great.
Good luck!!!
Old 10-15-2011, 11:41 AM
Thx for the folow up and reply.
Sounds like a nice fix.
My windstar served me well and brought me $4,500 in the great Obama buy back program.
It's now serving me as a Mazda 3 with a 5- speed stick.
