Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 10-18-2008, 12:42 PM
shmarkham shmarkham is offline
bronco2 alignment problem!
I have an 88 bronco 2! when i got it i noticed it was pulling to the left. after a got it out on the road irealized that if you turn left then go straight it pulls left. if you turn right then go straight it pulls right! I check the suspention over and found the passenger side radius arm braket was rotten! i've replaced that. but it did not fix the problem! all the tie rods feal tite! although if i twist them they feel like they bind a little! does anyone have any idea what the problem could be?
Old 10-18-2008, 01:06 PM
Scrapper Scrapper is offline
AF Premium User
Re: bronco2 alignment problem!
you may have to ajust sterring box or you may even have to change the gear box it self. good luck.
Old 10-18-2008, 09:17 PM
ya i've been looking into that! now that i'v daired to drive it. it turns out that it is just not returning on its own! i need to manualy turn it back to straight! i've been trying to go threw it step by step! hop[ing it's not the box! there not cheap and no local junk yard even have a bronco 2 in it let alone any parts!
Old 10-20-2008, 07:47 PM
rhandwor rhandwor is offline
Make sure the steering box is bolted down securely. Chevy 4x4 used to pull out of the frame and I had to send them to a body shop who welded the frame and added more metal.
Old 10-20-2008, 07:54 PM
AF Premium User
dose that have power steering or armstrong?
Old 10-21-2008, 01:50 AM
Davescort97 Davescort97 is offline
Escort guy
Steering gear is adjusted too tight. Back off the adjusting nut on the sector shaft and turn it counterclockwise until if frees up, then readjust backing off 1/2 turn after it connects with the gear. It is real easy to accidentally adjust them too tight while trying to get rid of play in the system.
Old 10-25-2008, 08:02 PM
old_master's Avatar
Advisor/Moderator
What you're experiencing is called "memory steer". It can be caused by the gearbox being adjusted too tightly as suggested, or a host of other issues. This website explains, Scroll down to "Memory Steer". http://www.aa1car.com/library/steerpul.htm
Hope this helps.
