Old 03-16-2003, 06:52 PM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
B16a1 vs. B16a2
B16a1 vs B16a2
Im thinking about building up a engine... i have found jdm b16a1 long blocks for as low as 600$ i will worry about the transmission and stuff later on. What is different on a B16a1 from a B16a2, i know they had different transmissions, but would a newer B transmission bolt right on? is there any big disadvantages to the b16a1?
Kyle
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 03-17-2003, 04:19 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
the b16a1 is obd 0 160hp
the jdm b16a2 is obd 1 170hp
the usdm b16a2 is obd 2 160hp
there also the usdm b16a3 obd 1 160hp, del sol vtec motor
since u have a 95 integra, idk what is taht a obd 1 car. well i would get an engine that is the same obd as your car so you dont gotta deal with the wiring.
yes the newer b series tranny will bolt right up. the b16a1 is a cable tranny. yoru car is a hydro tranny
Team Lonely Drivers
Old 03-18-2003, 09:24 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
why would you want to put a b16 block in your car? put the b16 head on your b18 block and have a lsvtec, probably would be cheaper that way too, what exactly are you trying to do?
2002 Acura TL Type S
1991 Honda Crx Si
Old 03-18-2003, 01:40 PM
Thanks for the info! It wouldnt be going into my integra... I got a possible project civic for it....
Kyle
1995 Honda Civic EX
-Turbocharged
-Many mods
Old 03-18-2003, 05:47 PM
oooooooooooooooh that would explain it
1991 Honda Crx Si
Old 03-20-2003, 10:04 AM
Paonessa Paonessa is offline
i didn't think jdm honda engines had #'s after the call sign.
ie usdm b18c5(type -r) as opposed to jdm b18c.
keep in mind i'm a nissan guy so i may be mis-informed
Old 03-20-2003, 10:54 AM
correct me if im wrong but you can get either a b18c1 2 or 3 gsr and 5 type r,but only the 4 is in japan and not here
1991 Honda Crx Si
Old 03-20-2003, 11:35 AM
my friends engine just says b18c. no #4 afterwards or anything. i have a couple of friends with jdm honda engines 1)a b16 in a hatch and my boy with the b18c in a dx coupe(this car's a bullet) and none of them have numbers on the end. what japanese car has the B18C4
Old 03-20-2003, 12:11 PM
ok the b18c3 and c5 are type r motors, idk how much hp the type r puts out
the b18c1 is a usdm gsr 170hp
the b18c2 and c4 are jdm gsr motors. the power in these is in betweent the type r and usdm gsr, so about 180hp
the jdm engiens dont come with a number after b18c, so u can get any b18c and u wont know it, but if its jdm and not a type r then u got either a b18c2 or c4, both are suppose to be same hp. if u do got a type r then its either the c3 or c5. and the c1 is a usdm motor
Team Lonely Drivers
Old 03-20-2003, 01:30 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Not even close,B18C4 is from the 96+ EDM civic VTi 1.8.
The The B18C6 is the EDM typr R teg motor.
The B18C5 is the USDM type R
The JDM motors don't have numerical designations so the JDM type R is just B18C and it is called the B18C R to distingush it from the B18C GS-R
The B18C1 is the USDM GSR
The B18C7 is the Australian type R I believe.
