Old 10-17-2008, 10:00 PM
DrivenByDemons DrivenByDemons is offline
Power Steering flush works GREAT!!!
Just lettin' anyone interested know, I did he PS flush tonight and it cured my growling noise during turns. If anyone is doubting this fix, just do it!
Old 10-20-2008, 10:49 AM
mundy5 mundy5 is offline
Re: Power Steering flush works GREAT!!!
glad to hear that you have experienced some silence on turns. did it myself a while back and it has been whisper quiet since.
2003 Windstar LX
1998 4dr Civic LX
Old 10-21-2008, 08:39 PM
MARZBX157's Avatar
MARZBX157 MARZBX157 is offline
Same thing here guys,
Did mine back around 52k miles after having the whining noise at turns. I'm going on 65k now and no problems at all, i have Mobil1 ATF in mine.
2000 Windstar 3.8 V6
Old 10-22-2008, 04:56 PM
garync1 garync1 is offline
Did mine 2 yrs ago. Used Advanced auto ATF.. I think its about time to do it again.. My Steering is not making noise like it did before I changed it to years ago. In fact its not making any noise. But I guess why wait. Its only causing damage when the noise starts.
Old 10-22-2008, 07:41 PM
hoofarted hoofarted is offline
I have been thinking of flushing my steering system soon. What kind of fluid did you all use?
Old 10-22-2008, 08:07 PM
CoolasIce CoolasIce is offline
Are you sure it's the flushing/cleaning that's making the difference, or is it just the topping off the fluid?
Old 10-22-2008, 08:55 PM
Changing out the fluid is what cures it unless its damaged.. The fluid degrades over time and looses it protection.
Old 10-23-2008, 06:32 AM
wiswind wiswind is offline
The 2002 windstar will use Mercon V rated ATF for power steering fluid.
The original fuid called for was Mercon, but FORD issued a TSB last year saying to use Mercon V in the power steering (Mercon V was already specified for the Transmission).
FORD has discontinued Mercon, so most fluid will be labeled as Mercon V , and also state that it is "For applications calling for Mercon".
The Mobil 1 that someone mentioned would be an excellent choice......
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-23-2008, 09:28 AM
I know this was discussed before.. I just remember seeing my owners man. Saying not to use Mercon V in the power steering, only the trans. Now they are saying its ok.. That bothers me at times.. I also remember in 1995 I bought a new Thunderbird and asked the service department if i could use synthetic motor oil and the guy said yea!! But it would void my warranty and guess what now they use a synthetic blend.. You can still get ATF fluid in After market but if it does not harm it I guess the Mercon V would be a better solution... I think its a synthetic.. I also use synthetic brake fluid even though it says not to and I have no issues at all.. Better brake pedal feel as well. I use the Valvoline synthetic brake fluid. Its formula should not eat the seals and orings. Just my 2 cents..
Old 10-29-2008, 05:48 PM
sparebeer sparebeer is offline
I had the power steering whining and whistling when cold on our 2002 windstar. It finally started foaming in the reservoir and leaking. I found that there's a very fine screen inside the plastic remote reservoir - it's under the fluid level so you can't see it when you look down inside it. I removed the reservoir and cleaned all the black gunk off the screen. It's nice and quiet now.
Old 10-29-2008, 06:52 PM
I still would get the fluid changed.If its been there since the van was new. Once you have to get the rack replaced you will wish you did... Plus you will notice the vans steering will feel a lot better...
Just when you think you are done. Your not!! Clean the tools. Then you are done.
Nothing impresses a single mom better than a single dad who drives a minivan.Just kidding
Old 02-17-2009, 09:48 PM
keithmcclees keithmcclees is offline
My 97 has had a problem where I must refill the power steering fluid every few weeks, do you think this will work for me or should i get it looked at? I have not driven it for a few months and right now it kinda sounds like a dragon during mating season....whatcha think?
Old 02-18-2009, 07:03 PM
vikko#80 vikko#80 is offline
HI!!!! my windstar 99. 3.8 shuts of when I make turn to the L. O. R. somebody can help me please .. THANKYOU
Old 02-20-2009, 12:23 PM
Dekeman's Avatar
Dekeman Dekeman is offline
I highly recommend doing the PS flush, especially with the Mobil 1 ATF mentioned. My steering was 200% better after completing this! See my post http://www.automotiveforums.com/vbulletin/showthread.php?t=728209 for my experience with this procedure. You should do it if you have whiny steering, because as Gary said, it's causing damage. I'd much rather go through this than replace my entire steering rack!!
Old 02-20-2009, 12:27 PM
Dekeman's Avatar
keithmcclees, I'd check the PS fluid level and top it off to see if the noise improves. You likely have a leak, and I'd look at the the hose connections first- in and out of the reservoir and pump. If no joy, go under the vehicle and look for a leak, because it may be your steering rack.
