Old 10-17-2008, 08:27 PM
jocro jocro is offline
2002 radio stays on......blower motor stays on....
Sometimes with key out of ignition switch radio will stay on, another time it is the blower fan, opened door and all the lights on the instrement panel were on like as if I was attempting to start it. Doesn't happen all the time but it has lost its dependablity. Couldn't start one time and appeared that I was not getting fuel...changed filter ......was not getting fuel to filter....decide fuel pump in tank bad. Last attempt to start prior to dropping tank it started up like new..................very frustrating. any suggestions? thanks....JOE
Old 10-17-2008, 08:42 PM
Scrapper Scrapper is offline
AF Premium User
Re: 2002 radio stays on......blower motor stays on....
did this do this before you replaced fuel pump? if so it's probably
in your igs. switch.
Old 10-17-2008, 08:45 PM
AF Premium User
in your igns. switch.
Old 10-17-2008, 09:54 PM
we never got around to changing the pump cause my young son tried to start it and it fired up. Is there a lot to changing the switch? and is there a way to be sure the switch is bad. thanks for you reply...........JOE
Old 10-18-2008, 01:43 AM
AF Premium User
first i would have pump tested by guage on fuel pump because it started is it still starting? if it is then get haynes manual for that car at auto zone or advanced if you got one of these around and it will show you the way to put cyl in.
