Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 10-17-2008, 09:00 PM
eric1h eric1h is offline
Aero comparisons....
So in another thread we started talking about the benefits of the aero on the car. So, since i am planning my aero mods I have been playing around with some CFD data........here are some results so far.
It's just a 2d rendering, so its not 100% accurate, but it gives you an idea......
talk amongst yourselves...
Don't know if any of you care, but I do so
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 10-17-2008, 11:48 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
Re: Aero comparisons....
Nice analytical work. Why do you say that since it's only 2-D that its not accurate? Sure the cross section changes, but it cure gives you a good idea of pressure regions. From what I can see, the rear wing needs to be as higher or slightly higher than the roof line so have much impact. The splitter doesn't seem to alter flow much. But it's a balancing act. A bit of down force up front and a bit in the rear is beneifical. What am I missing?
Jerry
1999 Panoz GT-RA
Old 10-18-2008, 08:39 AM
you are spot on with you analysis. The wing needs to be as high as possible to be the most effective.
The reason i said it was 2d and not 100% accurate is it doesnt take into account the holes in the front bumper, and the gaping hols under he car and other misc data, but you are right its a basic analysis to help fine tune the aero on the car.
Old 10-18-2008, 09:36 AM
Squerly's Avatar
Squerly Squerly is offline
Squerly
Old 10-18-2008, 04:28 PM
Tiny White Tiny White is offline
hay guys when they buit the panoz car it need to cost efficient if my memory is right the wing need to be back 12inch and up 6in or 9in with a 1/4 in grannie
Old 10-18-2008, 05:19 PM
hay guys take look at the old panoz trans am car that will give you some ideal about the wing spilter fender flars that thing was a rocket ship when it was builtit had 550 to 600 ponys the driver was borsie said
Old 10-18-2008, 08:46 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Our wings need more cowbell.
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 10-20-2008, 12:28 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Why would putting the wing too low save anything on cost? I can understand using the plastic front air dam vs. a true splitter, but not making the spoiler work out back.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 10-20-2008, 09:26 AM
Extra $5 in aluminum?
Old 10-20-2008, 10:07 AM
Squerly's Avatar
Yes, I've wondered this same thing too. I've heard from several sources that the positioning of the wing renders it non-functional. I personally don't know if this is true or not, but apparently there is at least some truth to it.
So why waste the money even putting it on the car? Looks?
Squerly
Old 10-20-2008, 10:09 AM
Ive spoken to some folks close to Panoz as well who said the same thing, they wanted a spec series and wanted to keep the speeds "low" the car was actually faster without the wing but the car looked goofy without it. So, they put it low to keep it as worthless as possible but made the car look better.
Old 10-20-2008, 11:11 AM
Cobra4B's Avatar
Hmmm... The GTS isn't a spec race car though. Only the GT-WCs were/are.
Old 10-20-2008, 12:15 PM
Gatorac's Avatar
Gatorac Gatorac is offline
GTS was a spec car.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 10-20-2008, 12:18 PM
Cobra4B's Avatar
Originally Posted by Gatorac
GTS was a spec car.
I thought the GTS was designed to run in GT2 or something? Not race against other GTS'.
Old 10-20-2008, 12:26 PM
Gatorac's Avatar
http://www.panozauto.com/EsperanteGTSDetails.htm
The Panoz GTS is built from the ground up as a driver's class spec racer....
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
