Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-17-2008, 06:01 PM
danjs danjs is offline
98 Bonniville temp actuator
I am trying to get to the temp actuator to change it and don't know how t get to it . It is behind the air bag and on top of the heat and AC module HELP????
Old 10-17-2008, 08:49 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 98 Bonniville temp actuator
Welcome to AF! Ihope this helps. Its not easy to get to!
Old 11-01-2008, 12:36 AM
rvcII rvcII is offline
Ron Here
I just changed mine out and I had to remove my climate control programmer and using I believe a 7mm socket I had to reach up on top of the temp control valve and find the screws, you should be able to take them out with a socket and your fingers because there isn't room for a ratchet. I would look at the new part and get familiar with the location of the screw holes because you will have to do this blind and I hope you have long arms.
