Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-17-2008, 06:13 PM
Juancm Juancm is offline
vibration problem
my car starts vibrating at 60 mph,i did a wheel balance on 4 tires.but still vibrates.i notice when going Straight at 60 mph car vibrates but doing slight turns without slowing down car stops vibrating.also car vibrate when coming to a stop i know it the rotor,but can this cause the car to vibrate when not using the car???????
Old 10-23-2008, 07:07 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: vibration problem
you might have a bad wheel bearing or suspension control arms or tie rods. Check for looseness
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 10-24-2008, 12:10 PM
i did,looks good.ithink its the tire on my rims because i install the front stock rims .took it for a ride no vibration at all,
Old 10-24-2008, 09:07 PM
Franco2112 Franco2112 is offline
Could be your tires!
