Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 10-17-2008, 05:14 PM
davidwardlow davidwardlow is offline
Cylinder/Chamber Compatibility
Maybe I'm Poser in the VW world but I have recently become the owner of a custom dune buggy with an air cooled engine. Though the engine appears extremely simple to rebuild I need a little help with new cylinder/piston/head selection.
1. will any size cylinder retrofit directly to my block
2. will I be required to replace the head if I change the cylinder size
3. how do I match the stroke length of the crankshaft to a cylinder/piston kit
4. what is meant by Type 1, 2, 3, etc.
Any education on these subjects would be awesome
Old 10-17-2008, 10:13 PM
BoatCop's Avatar
BoatCop BoatCop is offline
Re: Cylinder/Chamber Compatibility
Congrats on your new toy!
#1. This all depends on what's on there now. The only way to know for sure, is to mike out the cylinders and see what size it is. Generally speaking, if it's a stock 1600, then only 1600cc or 1641cc jugs/pistons will fit without machining the case. Any size can fit with machine work.
#2. Again, it depends on the size you go with. The bigger the cylinder, the more air you'll need to feed it, so you'll have to go with larger valves to get enough air in and exhaust out.
#3. Sorry, I can't help on this one.
#4. "Type" refers to VW model:
Type 1 = Beetle and Ghia
Type 2 = Transporter (Bus, Van, Single Cab, Double Cab, etc.)
Type 3 = Squareback, Fastback, Notchback, etc.
Type 4 = 411, 412 models, only built between '68 and '74. (picture below) They were intended to be a "Luxury" model VW, but popularity never caught on.
Alan
BoatCop
