Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-17-2008, 02:27 PM
Tony022 Tony022 is offline
Remote entry
1995 Aurora Remote entry fails
Keys were in pocket and I got wet while surf fishing...
It worked last night coming home but this morning it fails to open doors or trunk..
I checked batteries,, 3 volts each... Did I short out the unit??
How can I check that out and if so, other than a dealer where can I find a new remote entry device...
What has to be done to the unit to tune it to my car..
Thanks
Old 10-17-2008, 10:23 PM
RsFKevski RsFKevski is offline
Re: Remote entry
Yes, it's pretty well toast, if it was submerged in water. Typically you can find them on the internet, but beware, they may not work properly for your vehicle. I would only trust one from a dealer and yes, they can be programmed to your vehicle. A new remote will come with instructions on how to program the new one to your car.
Old 10-18-2008, 09:39 PM
Re: Remote entry
It was not submerged under water...in my pocket when it got wet..
Anyhow,, Does anyone have the instructions on how to program the unit.
1985 aurora. I would like to try to reprogram the unit before I buy another one..
Re: Remote entry
Old 10-20-2008, 04:15 PM
Re: Remote entry
http://www.handa-accessories.com/crv/KEYLESSPROG.pdf
There's your instructions that are needed. Good Luck with your 95
Old 10-22-2008, 12:37 PM
Re: Remote entry
Thanks--------That did it....
Old 10-23-2008, 03:49 PM
Re: Remote entry
Glad to see that it worked
Old 01-25-2009, 09:50 AM
Deadly Furby's Avatar
Deadly Furby Deadly Furby is offline
Re: Remote entry
Did it work because you purchased a new one or did it work because you were able to reprogram the one that got wet?
Old 02-02-2009, 07:34 PM
Re: Remote entry
Reprogrammed the one I had..
It works fine..
Thanks
Old 03-17-2011, 06:34 AM
Re: Remote entry
OK old one worked for a while and died.....
Where (on-line) would you recomend buying a new/used remote for
95 aurora? and do they come with programming instructions?
Old 03-17-2011, 09:18 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Remote entry
Had to chuckle- not more than one inch away on my screen was this google ad
https://www.ikeyless.com/vehicles/Ol...FQQ65QodUiWP_Q
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-17-2011, 11:23 PM
peeweewasblue peeweewasblue is offline
Re: Remote entry
On the back of the remote there is a number about 8 digits long.
Mine is 25678792.
Type that number into a search on ebay and normally a lot of them will come up.
Old 07-08-2011, 04:08 PM
rcjhgoku rcjhgoku is offline
Re: Remote entry
OK, how about this one. I ordered a key Faub from ikeywireless, eveything on their end was good. I tried jumping my dlc or what ever its called. I jumped 4 & 8, the doors cycled through a lock cycle, which was supposed to happen, then right after my lights started going haywire and clicking. Now, my dash does not work and every time I put my key in the ignition my interior lights go off. Any ideas? There was some clicking in one of the modules under my back seat but didnt know how to proceed so I left it alone... someone help! Thanks
Old 07-13-2011, 01:30 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Remote entry
Make sure you are not pressing the brake pedal at all during the procedure as it will interfere with programming mode.
Also, some customers report success programming with the driver's door open - where others report success with all doors closed.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
