Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-17-2008, 11:36 AM
RACER2416127 RACER2416127 is offline
Angry clutch engage problem
hi,i just replaced the clutch pressure plate throw out bearing slave an master cylinder,but cannot get enough clutch peddle to get it in gear,i adjusted the rod under the dash,its out all the way,im real close to getting enough peddle,anyone have any ideas to wat i need to do next,thank you,my car is a 1991 eagle talon
Old 10-17-2008, 12:00 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: clutch engage problem
Please use more punctuation when making a post. Very hard to read.
Put the adjustment back to where it was. Rebleed the clutch line. After you do it... rebleed again.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-17-2008, 12:10 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You probably have air in your hydrolics. Bleed the hell out of your system and then set up the adjustments. Someone on here with a 4g63 can help you with that. The 420a clutches do not have adjustments like that.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-17-2008, 03:36 PM
steviek's Avatar
steviek steviek is offline
|THis type of clutch engagement/disengagement problem is very typical in dsms. There is a clutch slave cylinder extension rod which you can purchase. That often helps.
http://www.extremepsi.com/store/cust...&cat=691&page=
The other thing is to switch to a ss braided clutch line and bypass the accumulator.
http://www.extremepsi.com/store/cust...cat=612&page=1
And yes bleeding the clutch line always helps.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 10-17-2008, 03:50 PM
ok,ive blead the heck out of it.no signs of any air bubbles.i adjusted the rod back where it was.now my pedal is closer to the floor.when i lenthen the rod under the dash,my pedal gets better,its almost there,but i run out of rod.its all the way out.ive noticed something,maybe its suppose to be this way.the pedal go,s down about half way before it even moves that rod.is it possible i have a bad peddle assembly.
Old 10-17-2008, 03:53 PM
i have the longer rod on the slave.im stumped.
Old 10-17-2008, 04:29 PM
Holset powered 420a
Check to make sure your slave or master cylinder is not leaking. Doesn't sound like it but it never hurts. Also it may help changing over to a SS line. Mine got old and some times the clutch wouldn't release bc the line would balloon up some.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-17-2008, 06:22 PM
i just came in,put the old master cylinder on it,same deal.see before i ever put any new parts on this car.the car was the same way.infact my boy drove it,but had to put it in gear an then start it.after he got going it was ok.well,he end up getiing the trans stuck in two gears.so i put a new clutch kit.plus a good used trans,because the other one was shot.new slave an new master cylinder.the clutch pedal is the same way it was before.thats why im thinking its the clutch pedal.has anyone ever had a problem with the pedal assembly
Old 11-30-2008, 09:43 PM
eagletsi1040 eagletsi1040 is offline
did you have somone holding the clutch in then open pleeder do that couple time then adjust rod under dash if you need to
Old 11-30-2008, 10:53 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
It seems like you have replaced everything that can be replaced. Swap your clutch line to the braided one, and then bleed it over it and over and over and adjust your pedal. I had to bleed the pure-t-shit out of mine, but it finally got there.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
