Old 10-16-2008, 07:48 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
sway bar upgrades
I want to upgrade my suspension and stiffen it up a bit... across the board.
I'm putting the Si rear disc brakes and suspension on my car, which means I'll have mount points for a rear sway bar...
I don't hella drive.. but I don't like body roll either... I want to replace the front and rear bars with something better, but I don't know what to use... any suggestions?
BTW, I'm using Espelir Progressive 50mm static drop springs, and I definitely don't want any issues with rockers rubbing... I want my car to feel like it's laying flat on the corners, regardless of over/understeer.. I can adjust my operation for that...
So... suggestions? Shoot!
P.S. Obviously, you can't ride stock flaps on a 50mm drop... meaning that they'll be up for sale... Tony and Frodo get first dibs, since I believe I told them both awhile back that I'd look into some for them.
If they don't want them, they're up for the highest bidder + shipping.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 10-17-2008, 01:09 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: sway bar upgrades
Front and rear? Oh hell yes im in! I missed out on a set for 25 a few month ago and im kicking myself.
Oh btw as for simple sways. DA bars front and rear. Keeps a decent balance, but are stiffer than the stock civic pieces since they were meant for a heavier car. No welding or anything required for mine, I just flipped the LCAs around and swapped the chassis mounts on the bar to match the tow hook bolt pattern. Also the front will bolt right up.
Way cheaper than spending 300+ on ST bars or tanabe bars.
http://www.honda-tech.com/zerothread?id=1894834
Going from a car with NO sway bars to these was like driving the car for the first time again.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-17-2008, 04:34 PM
So... will DC2 Integra bars fit? or umm... anything else... maybe just slightly stiffer than the DA bars?
Old 10-18-2008, 03:27 AM
FrodoGT's Avatar
Nope, dc bars wont fit at all. Not that they are any stiffer than the DA bars.. I dont think they would just keep making them bigger.
Current project:
Rio Red 91 hatch.
Old 10-18-2008, 09:02 PM
Well, I wondered, since the DC's are heavier... so yeah.
So.. umm.. if I use the DA bars, and lower my car 2 inches on progressive springs, do you think it would lay pretty much flat around corners? I'm also preloading the springs after I lower the car to about 100lbs per corner, which will take up the initial slack that most street springs and shocks have. (Gives a faster response time to driver input, makes the car more nimble and responsive.)
After I lower the car, should I have the alignment reset to stock specs? Or is there something that will work better for me w/o wearing my tires up...
Old 10-19-2008, 12:01 AM
FrodoGT's Avatar
You can run about 1.5-2 deg of camber up front and 1.5 in the rear, that seems to be the general happy medium for camber.
Also I think it will lay completely flat. I don't think the preload is really necessary at all, maybe overkill and just asking for a twitchy car but play with it and see what you like.
Current project:
Rio Red 91 hatch.
Old 10-19-2008, 12:10 AM
Well, I'll have DA bars come next weekend then. I'll just have the kid that I'm trading the ZC to get them from his local, and throw them into the trade.
So, I need the DA sway mounts and endlinks too, right?
Old 10-19-2008, 12:29 AM
FrodoGT's Avatar
For the rear, yes, for the front no. You will need end links for the front if you dont have them already, but the civic chassis mounts are slightly different tha nthe DA and you need them, the bushings will fit in them though with no problem..the only difference is the inner diameter (sway bar size).
For the rear, if you dont have rear sway bar mounting locations on the body you have a couple options. Use the tow hook poits to make plates and weld the mounts to the plate, or do what I did. Flip the control arms left to right, flip the sway mounts left to right and bolt it to the hook location. Done.
Current project:
Rio Red 91 hatch.
Old 10-19-2008, 12:35 AM
Well, I have a front swaybar... I'm pretty sure all sedans do... I don't have a rear, as yet... dunno if I have provisions for a rear or not, only way I would is if the EX or LX had one stock... b/c they used the same chassis pans... but I don't think either did.
I'll have to figure that part out. My rear tow hooks are already gone, I removed them b/c I never use them. I can pretty much put anything there that I need, I just have to be careful that it won't interfere w/ my jew'd exhaust and my class 2 hitch... The exhaust is getting changed eventually, but not until I get a 8gal fuel cell that fits in the spare tire well, and is DOT approved.. then the exhaust gets re-routed to come out the side of the car.
I'll have him get the mounts and endlinks for me anyway, it won't cost anything more, and I can probably use them for something in the future.
Old 10-19-2008, 12:44 AM
SO, I'm guessing from checking links on the subject that my car won't have the holes threaded, they'll just be popped holes in the subframe... with no welded in nuts. Easy fix: Weld in nuts. I'm not making a plate or anything, I'll just wait until I get the hardware that I need from an Si and use it... keep it as stock as possible.
This car is pretty much my guinea pig for how far I can hybridize it and make it look like it came that way... I'll take as long as I need to learn how to do it right on the next attempt.
BTW... wtf do I do w/ a A6 w/ 92k on it? The kid w/ the rims flaked on me.
Old 10-19-2008, 01:03 AM
FrodoGT's Avatar
Forget the hole, threaded or not. I used the more than sturdy tow hook holes.
Didnt have to weld a damn thing lol. I did have to drill out the mount brackets from 10mm to 12mm though, but that took..oh..about 2 min total.
Current project:
Rio Red 91 hatch.
Old 10-19-2008, 01:05 AM
FrodoGT's Avatar
D17 stroker?
Current project:
Rio Red 91 hatch.
Old 10-19-2008, 01:06 AM
FrodoGT's Avatar
Now that I think about it (also whoring a triple post..im on a roll) the 4d may have those hooks a bit farther away than the hatch does, but its def worth a shot.
Current project:
Rio Red 91 hatch.
Old 10-19-2008, 09:16 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Well if his hitch is like mine, its taking up the tow hook spots...if its not, I have no idea where he hooked it to and why.
I will need to source up some front sway bar stuff at some point, just realized the black ED has no sway bars and rocks like a damn boat. I haven't got to drive it yet, just finally got an engine sitting in it and spindles swapped so it can roll again.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-19-2008, 10:55 AM
My hitch actually just bolts through the rear sub-frame, it will end up being carriage bolts in the trunk floor, which of course will have a plate over the sheet metal.
I opted to do it this way b/c It'll spread the weight load over a larger area than just making a longer plate to bolt it up to the tow hooks... which are about 2 feet from the end of my bumper... that would be some serious leverage on those three little bolts if I put a util trailer on the hitch.
The sedan's "foot longer-ness" comes after the complete suspension, including the tow hook mounting points. They're in the same place from EF to EF, but on the sedan, they're further in than on other EF's, b/c of the trunk.
