Old 10-16-2008, 05:54 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
97 Grand Prix SE - Rear Wheel Bearing Removal
I need to replace the right rear wheel bearing on my 1997 Pontiac Grand Prix SE. I have removed the wheel, removed the caliper, and removed the four bolts that I thought were holding on the rear wheel bearing. I can't get the bearing to let go. How do I get the bearing lose from the spindle? Please help. Thanks.
Old 10-17-2008, 09:01 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 Grand Prix SE - Rear Wheel Bearing Removal
It's probably rusted in, so a weighted head convincing tool may be required.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-17-2008, 09:07 AM
Yeah, I kind of figured it was rusted. Just did not want to assume that and break something in the process. I will hit it with some WD40 and let it set. What exactly is a weighted head convincing tool? I sincerely appreciate your help.
Old 10-17-2008, 10:06 AM
richtazz's Avatar
a big hammer,
Old 10-17-2008, 10:22 AM
When all else fails, get a bigger hammer...LMAO.
Old 01-22-2009, 04:16 PM
Mike7468 Mike7468 is offline
How much difference is there to replace the Front Wheel Bearing Hub on a 1997 Grand Am??? May be purchasing one in the next few days.
Old 01-22-2009, 08:28 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Difference will be it has 3 bolts holding it to the spindle, along with an axel nut that needs to be removed. Otherwise same deal. Remove brake caliper, caliper bridge, rotor, axel nut, 3 hub bolts, and you should have it.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
