Old 10-16-2008, 11:19 AM
rtreptow rtreptow is offline
Heater working intermittently
I have a 2000 Blazer 4 door. My wife drives this vehicle. She said for the last few days on her way to work, the heater blows hot air shortly after the truck warms up, but about 10 minutes later, it starts blowing cold air? The fluid level is fine. If it matters, the radiator was replaced about 3 months ago. Could this be a thermostat problem?
Old 10-17-2008, 08:13 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Heater working intermittently
Could be a problem with the blend door under the dash.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-25-2008, 07:44 AM
NINFan NINFan is offline
could they have used non-dexcool antifreeze when they replaced the radiator? causing a blockage in a heater hose?
Old 10-25-2008, 11:19 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Auto or manual AC/Heater controls?
Have you checked the stat for losing engine tempt?
Always pull rad cap when cold and check rad coolant level?
Feel heater both hose hoses for being hot to the touch.
MT
