Old 10-15-2008, 08:12 PM
djkroemer08's Avatar
djkroemer08 djkroemer08 is offline
trunk spattering
hey guys i got a 72 monte carlo its my first car so its a learning experience for me im sure ill be postin some more questions later on but i want to spatter paint the trunk i already got the spatter paint and i just wire brushed all the metal what do i need to do to prep it though do i need to put anything on before the spatter paint? thanks for the replies
Old 10-15-2008, 10:54 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: trunk spattering
The paint can should have some instruction on the appropriate primer, (if any) that is required before you paint. If there are none, see if the paint manufacturer has a website which has more info.
At the very least, I would sand down any rough spots and make sure there is no rust left on the area.
Then I would clean off any oil/grease from the bare metal using a spray can of brake cleaner and a lint-free rag.
Mask off any areas you do not want painted with masking tape and newspaper. Then apply any primer the can's instructions say is required.
Old 10-17-2008, 12:50 PM
MrPbody MrPbody is offline
AF -Advisor
DANGER! WARNING!!!
Many of the spatter-paints available are water-base. While they look great, if ANY water finds its way in and sits, the paint will disolve. Learned this the HARD way... If the can doesn't say on it, call the manufacturer and ASK!
Jim
Old 10-17-2008, 11:09 PM
wont a good clear coat prevent that
Old 10-19-2008, 12:05 AM
MagicRat's Avatar
So long as it does not 'lift' (dissolve) the spatter paint underneath.
Sometimes different paints are not compatible.
Again, contact the manufacturer of the paint for more info. If it is water based I am sure they can suggest a way of sealing it.
