Go Back   Automotive Forums Car Chat > Volkswagen > General Discussion
Old 10-15-2008, 04:44 PM
christiank christiank is offline
Car battery problem
I just bought a new battery for my vw passat. the battery has side terminals. I hooked it up, pos to pos neg to neg, and when i try and start the car, is sounds like its trying to turn over but no luck. I'm getting power to the power windows but the stereo, lights and clock aren't on. Any ideas?? Thanks.
Old 10-15-2008, 05:03 PM
Franco2112 Franco2112 is offline
Re: Car battery problem
Sounds like our new battery has a bad cell. Take that one back and exchange for new one.
Old 10-16-2008, 02:53 PM
I dont think thats it, this is the second battery i've tried. Could it be a fuse problem?
Old 10-16-2008, 03:46 PM
OK. Any issues before you changed the battery? If not, your first start is to check every fuse and relay. If all are fine you will have to check your cpu with OBD-II scan tool and see if any codes are brought up. If you don't have a OBD-II scan tool you may be able to rent one from the autoparts store.
Old 10-23-2008, 06:18 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
if you have a 1.8t engine than check the timing belt for failure (remove the upper cover and see if the cam spins when the engine is being cranked over)
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 04-02-2011, 08:09 AM
Aidenemily Aidenemily is offline
Well i think i have done all these to make my battery work but i think there must be some major problem with my battery so i need to check it with a mechanic which i am going to do now ,and guys thanks for all your support and help .
