Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 10-15-2008, 04:34 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Water lines to turbo
I'm basically just wondering if it's worth it to add the water lines to the t3/4? Never really paid attention to them before and it seems from some research that only turbos putting out high power (thus more heat) really need the water cooled option. I don't see how it would hurt a smaller turbo. Any input?
Also, where would the lines come from / go to? Does it have to be coming from specific spot like the oil feed line? Need a restrictor?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-15-2008, 10:58 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Water lines to turbo
I know on a stock 2g, you have your water lines coming from the water pipe across the front of the block and off the lower half of the thermostat housing... Not sure if it's all that beneficial to a smaller turbo. Probably just more lines in the way if anything...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-15-2008, 11:17 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Though, it may not be required, or even beneficial, I added water lines to my turbo. I have a 14b, and since my motor is NA there was no previsions for a water source for the turbo. So all I did was take the turbo to advance auto and get some barbed brass fittings that screwed into the water holes into the turbo. Then I ran rubber line from there to the water feed for the throttle body, and back. I originally used rubber fuel line for the water lines, but it wasnt long before it cracked and leaked. So I switched to rubber transmission line and that has proved to be waaay better. So basicaly I slipped the lines onto the barb fittings and hose clamped them.
I hope that wasnt too confusing to follow, im not good at explaining stuff.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-15-2008, 11:50 PM
david-b's Avatar
Dave is THAT guy
Ya i got it. I would use SS the whole way anyways. The 420a don't have coolant lines to the TB though so I would have to find another way. Probably tee off the thermo housing and then back to the lower radiator hose somewhere.
75 Monte Carlo
Old 10-16-2008, 08:11 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It just keeps the center section of the turbo running a little cooler. Not sure if it has any benifits. I have never water cooled any of my turbos and pulled it apart resently and it didn't seem to have any build up or anything. As long as you idle the car some after you drive it hard.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
