Old 10-15-2008, 11:38 AM
nellybob's Avatar
nellybob nellybob is offline
95 escort
hi i have a 95 escort when driving its fine untill u press the clutch pedal and change gear
i have to literally fight the steering wheel to keep it in a straight line untill im in the next gear its fine again i have a whining coming from the wheel bearing and i know the wishbone needs replacing but could it be just these too to make the car control like this i accelarate the car goes fine as soon as i ease off it jumps to the left i was doing 80 once eased off to change gear and nearly ended up in a ditch could changing the wheel bearing and wishbone cure the problem
also just a quick question can i lower the escort 60 mm on 17s without rub and still have full lock
Old 10-15-2008, 11:59 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 95 escort
You need to shake down the front end, replace anything that is loose and then align.
Old 10-15-2008, 12:40 PM
inafogg inafogg is offline
Re: 95 escort
hello,so if u are cruising in 5th gear need to slow down a little & then accellerate back up the car acts normal??but if u slow down & need to down shift & then accellerate the car darts to one side??just making sure i understand problem.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-15-2008, 01:48 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: 95 escort
I'd start by jacking the car up and see if the wheels turn freely then look at the tie rod ends.
Nevada Tumbleweed
Old 10-16-2008, 08:29 AM
nellybob's Avatar
Re: 95 escort
no its just like if u boot it then ease of just a slight amount it goes the the left
checked the wheels this morning and the turn fine
the problem happens when going in to high revs then changing gear
i did a test yesturday and i drove it took my hands off the wheel and booted it the steering wheel jumped to the left and when i eased off went back again
Old 10-16-2008, 08:59 AM
Re: 95 escort
How about the tie rod ends?
Nevada Tumbleweed
Old 10-16-2008, 12:38 PM
nellybob's Avatar
Re: 95 escort
yes they are fine aswell no play and rubbers arnt torn i can only put it down to the wishbone
Old 10-16-2008, 01:15 PM
Airjer_'s Avatar
Re: 95 escort
Are you jaxcking under the control arms? If so find another spot, Under the rockers, and shake it down again. If you have a lower ball joint that is bad it will never show any play with the jack under the control arm!
Old 10-16-2008, 01:18 PM
nellybob's Avatar
Re: 95 escort
i never jack under anything like that i only jack on the jacking points
Old 10-16-2008, 09:31 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 95 escort
Check where the steering rack mounts to the firewall and be sure that the mounts are tight. I have seen a few cars where the mounts have come loose over time.
Old 10-17-2008, 04:23 PM
nellybob's Avatar
Re: 95 escort
tht might be half the problem yeah i never thought of checking there but i will tommoro let u know how i get on
