Old 10-15-2008, 09:25 AM
crroyalflush crroyalflush is offline
AC Question--04 Silverado
I have a 2004 Silverado LS w/ the 5.3. On occcasion the a/c will just stop blowing cold air. If I turn the truck off and back on then it starts blowing cold air again so I think its a switch, Im just not sure which one. Can anyone help?
Old 10-15-2008, 09:50 AM
brcidd's Avatar
brcidd brcidd is offline
Re: AC Question--04 Silverado
You (and we) need more hints.. Like does it do it when it is really humid?- or does the air flow quit, or does the the air just get hot? Is there a big puddle of condensate water under the truck when you shut it off? Is the compressor running when this happens? This would require stopping and crawling under the truck to see if clutch hub is turning- or at least feeling the low side pipes to see if they are warm, cold, or frosty?
Could be electrical, freeze-up, or something else at this point.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-15-2008, 10:03 AM
j cAT j cAT is offline
your cabin air filter may be plugged up...this is in the air duct under the dash next to the blower motor...this usually needs replacement often in dusty areas..replacement costs 20.oo...if you just discard this filter your evap will get plugged up ,and this will also give you your problem...perhaps this was already done..if so it will be pita.....
Old 10-15-2008, 10:42 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
My guess is either a pressure or temperature cut-off switch. I would get an HVAC manifold gauge set and watch when it cuts out. Does the high side pressure get too high? Low side pressure too low? Typically they will cycle back on once pressures have returned to normal. I'd also feel the accumulator pipes for abnormal temperature. One should be cold and sweaty and the other hot, but neither to the extreme (icy/frosty and burning, respectively)
Is the AC air good and cold when it IS running? A vent thermometer should read abt 40-deg at max setting and HI fan speed at abt 1200 rpm.
Not sure abt the cabin filter since that would obstruct all air flow, not necessarily stop cold air from being produced, but the original poster is a bit vague in that. But I will say that if the evaporator gets too cold from lack of airflow it could trigger a low-temp cut-off switch.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-15-2008, 12:08 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I'm going to take yet another approach. Under the dash on the passenger side is the resistor array. My friend Jim has an '06 Silverado, and his experienced exactly your problem. It was diagnosed as a bad resistor array, we replaced that (along with a replacement wire harness 'pigtail'), problem solved.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-15-2008, 12:45 PM
I havent noticed any specific conditions that create the problem, ie, humidity etc. The air still blows but it just blows hot air. When the air is cold, it works great and is cold. I havent noticed any larger than usual puddles under the truck when its shut off and I havent noticed if the compressor is still running or not. It seems pretty random when it does it but when it does, it will do it several times in a day and then it wont do it again for a while.
Old 10-15-2008, 02:11 PM
If the temp goes from cold to hot this may mean the temperature control motor is defective ..this is located directly above the hump in the floor under the dash...this is called a stepping motor..operates on 0-5volts dc
these have a good failure rate...
