Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-14-2008, 10:46 PM
v8_ranch v8_ranch is offline
97 Suburban - transfer case will not shift
Vehicle is 97 Suburban 1/2 ton 4x4 with 350 Vortec. 200,000 miles and tranny rebuilt at 115,000
For about the last 4-5 months, my transfer case selector switch does not light up and no shifting occurs with any button depressed (luckily, vehicle is at least in 2HI). Replaced the switch as I found one cheap - no change. When key turned to ON, the 2HI light comes on and then goes out a couple of seconds later. After that, no lights or anything. I found this thread tonight (http://www.automotiveforums.com/vbul...d.php?t=725584)
I tried the fuse replacement and no help for me unfortunately. I have been worried that is it coming down to the transfer case drive motor, but hoping it might still be something less costly. Any ideas on what else I can check?
Thank you,
Shane
Old 10-17-2008, 03:43 PM
j cAT j cAT is offline
Re: 97 Suburban - transfer case will not shift
Thank you,
Shane
I don't know for sure on a 1997 , but on the 1999 on up when this occurs and at your mileage this usually means at the minimun a bad encoder motor...ya it could be wires shorted and all of that in addition to the motor..
If you get DTC I can give you better facts..on what it is..
Old 10-17-2008, 07:36 PM
What is DTC and how do I get it?
Old 10-18-2008, 08:45 AM
a oem dealer can pull these as well as any repair shop that has a scanner that can read these manufacturer specific codes for the drive train. call and ask first if they can and how much to pull this code info..
Old 10-18-2008, 05:28 PM
777stickman 777stickman is offline
Shane:
DTC=Diagnostic Trouble Code and as stated only a scan tool that can access the Transfer Case Control Module will pull the codes. Over the counter code readers do not have that capability.
By the way, how many buttons are on your T-Case switch panel and how are they labeled?
The most likely cause is the t-case motor, but without the DTC's it would be a shot in the dark.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-19-2008, 09:07 AM
Originally Posted by 777stickman
Shane:
On my switch panel, there are 3 buttons: 2HI, 4HI, and 4LO.
Yesterday, after having the battery disconnected for some other work, I hooked everything back up an turned the key on and all 3 switch panel lights came on for a few seconds and then turned off.
No secret handshake McGuyver method of checking the codes eh... I guess I will see if I can find a sho; to help me out. Most around here charge $70 just to hook up the scan tool.
Old 10-19-2008, 09:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here is a 70$ tip on gettingn codes.
To get codes on that one ground pin 13 on diagnostic connect and count the shift button blinks.
The only have codes 1-4.
Post back code no.
MT
Old 10-19-2008, 09:31 AM
this cost of code reading WILL be the least expensive part of the repair...knowing the problem area is best known before repairs/parts are started.
If you have good mechanical skills this job is not very difficult..also there are motors available on line for a much lower price than the dealer...
Old 10-19-2008, 09:57 AM
Thanks guys. I was just thinking I had read somewhere before that these codes could be checked somehow without the scanner, like MT brought up. My only question though is for verification: when you say ground pin 13, you are talking about where the OBD scanner hooks up, or somewhere else?
Thanks again for the help. If I am going to have to replace the motor, I would rather put the $70 towards that if possible.
Old 10-19-2008, 10:03 AM
MT-2500's Avatar
AF - Advisor
Pin 13 in link below.
http://www.troublecodes.net/OBD2/
Ground it and flip key on and count blinks and save 70$
Post back code.
Good luck
MT
Old 10-19-2008, 10:14 AM
MT-2500's Avatar
AF - Advisor
All 3 button lights should blik together
If no codes button lights will blink one time and quit.
If code the shift buttons will blink code and the after a 3 second pause blink the code or codes again and again.
MT
Old 10-19-2008, 10:50 AM
I made an assumption off the link you sent me that I could ground pin 13 to pin 4 (chassis ground). Assuming that is good assumption, it appears I am getting no codes. All 3 lights came on, stayed on for maybe 3 seconds, and then go off and stay off. Did I make the correct assumption on the ground pin?
Old 10-19-2008, 11:00 AM
MT-2500's Avatar
AF - Advisor
Yes
Sounds like no Codes.
Back to the drawing board.
Good Luck
MT
Old 10-19-2008, 11:05 AM
Yes
Good Luck
if no codes, could it still be the motor? Does the fact that there are no codes tell me anything good about this situation?
Old 10-19-2008, 11:26 AM
MT-2500's Avatar
AF - Advisor
Very well could the motor or maybe be.
But could be wiring or shift buttons or power or ground problem.
But with no codes.
To be sure you need to do some proper testing.
A good factory service manual or a All data online sub will take you threw the proper test.
26.95$ US plastic and 10 minutes and you will be set to go on testing with a one year one car online sub setup.
http://www.alldata.com/products/diy/index.html
To be for sure run the test as outined in service manual.
Good Luck
MT
