| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
slave bleeding problems
ihave a 91 eagle talon,i put a new clutch an pressure plate,an i also replaced the slave an the master cylinder,ok,ive blead the slave over an over,still 1/2 a peddle,cant get it in gear,so i adjusted the rod under the dash,made it longer,made it as long as it will go,still wont go in gear,i can put it in gear an then start it up,an its releasing the clutch enough to do that,but it needs just a little more.ive noticed the peddle under the dash,i can push it down about 2/1/2 inches before it starts to move the rod that pushes into the master,is there a chance that somethings wrong with the peddle mechanism itself.
Re: slave bleeding problems
I GOT IT FIXED,it was the clutch pedal,theres a nut on the far side of the pedal ,rite by the adjustment rod,well it was loose an was letting the pedal move without moving the adjustment rod.tightened it up,now i have a full pedal,the pedal moves the adjustment rod as soon as you move the pedal.the car go,s into gear perfect now.
