Upper Cylinder head Gasket Repair kit Fel Pro
Good Morning> Does this kit have gaskets for the super charged motor. I have a 92 3800 motor without supercharging and have several gaskets left over. I have a couple of small square paper gaskets, a round black rubber gasket about an inch in diameter, and 2 plastic sleeves about a 1/2 inch long. I also have a larger paper gasket left over. Anyone know what these are???Thanks Arne
Re: Upper Cylinder head Gasket Repair kit Fel Pro
What was the part number of the gasket set? Sounds like someone sold you the Ultra (S/C) kit!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Part number is HS 9644 PT-1 Fel Pro
That is the right part number for the 92 PA N/A (non-S/C) motor.
The round black rubber gasket is for the thermostat. The plastic sleeves are to be used for installing the valve seals over the valve grooves without damaging the seals. The paper gaskets; would that be the thermostat housing gasket?
