Old 10-14-2008, 12:17 AM
d_crosson d_crosson is offline
Stereo Help (ground loops)
I have tried everything to get rid of the the annoying alternator humming in my speakers. I have tried different RCA cables, different speaker wire, different crossovers, different grounds for all three amps, the same ground for all three amps, power straight from the battery to the deck, different ground for the deck, running the RCA's and power cables on opposite sides of the car, unplugging the antenna. I think it might just be the deck, any thoughts or help.
Old 10-14-2008, 12:26 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Stereo Help (ground loops)
is it a pioneer headunit?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-14-2008, 12:59 AM
Yes, it is a Pioneer Premier DEH-P500UB.
Old 10-14-2008, 01:08 PM
pre98zetec's Avatar
pioneers are so notorious for rca noise. here's a simple fix, not a complete one but it does make it better.
http://www.icixsound.com/vb/showthread.php?t=40067
-Josh-
Old 10-14-2008, 06:12 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
interesting fix, but technically the signal ground is NOT chassis ground. I guess if you have blown the ground from hot-swapping the RCA's, chassis grounding the RCA's is better than no gnd at all.
Old 10-18-2008, 03:06 AM
So i switched out the deck to a clarion DXZ675USB, same problem. It is not the RCA's, the speaker wire or harness, the crossovers, the ground. It shouldn't be that i am drawing to much power form the alternator, i am only running about 300 watts RMS. It is also all hooked up to a capacitor, I don't think that has anything to do with it, but all three amps are hooked up to it. Any more ideas or suggestions?
Old 10-18-2008, 03:20 AM
I forgot to add that you hear just about all electronic noise in the speakers. Signal lights to changed songs on the deck.
Old 10-18-2008, 08:03 AM
Audio Guy
how are you grounding the cd player ? If you are using the ground from the wiring chassis .... DON'T. Ground the cd player to something metal behind the dash.
Old 10-18-2008, 11:19 AM
Neither the power to the deck or the ground go through the wiring harness, the power is to the battery and the ground is in the back of the dash.
Old 10-18-2008, 01:12 PM
Audio Guy
interesting, because what you are describing is usually the result of a poor ground.
Let's try a more scientic method to try and determine where the noise is coming from. Make shorting plugs for all the RCA inputs you have to the amps, unplug all the RCA's and anp put the shorting plugs in. A shorting plug is just a male RCA end where the two posts are pushed together and soldered if possible - it shorts the RCA input to signal gnd on the amp. Leave everything else connected like it was and start the car. If the noise is still there, it is one or more of the amps, if it's gone then it's further upstream. What other components (other than speakers) do you have in the system and where are they installed. Is the crossover active (before the amps) or passive (between the amp and the speakers) ?
Old 10-18-2008, 01:55 PM
It is a passive crossover, could it be the ground for the battery to the chassis.
Old 10-18-2008, 03:18 PM
Well i have triple checked all my grounds and everything else. I was listening to my engine and it sounds like the alternator was working very hard. I think i might be drawing to much current from the alternator.
Old 10-18-2008, 07:35 PM
Galuple Galuple is offline
What kind of car is it?
Old 10-18-2008, 11:59 PM
Its a 2000 Pontiac Grand am, 3.4L.
Old 10-19-2008, 10:16 AM
Audio Guy
you need to start at the amps and work your way back thru the chain .... just wildly jumping from one thing to the next will typically take a lot more time. I assume with that number of amps you have, that you are using the crossover in the headunit or the ones built into the amp. Does the alternator whine come thru all of the mid/tweet speaker groups or just one (some of them) ?
I can only assume you are drawing quite a bit of power, You will need three ground wires for the CAR. Battery to engine, battery to chassis, and chassis to engine. Many people do the big 3, whigh is replacing those wires with bigger ones (or just adding a bigger one on top of them) plus a bigger power wire from the alternator to the battery.
What amps are you running and how much power do they have ?
