Old 10-13-2008, 09:37 PM
SsHaDyGt SsHaDyGt is offline
Rocker arm installation?
Hi,
Anyone have these modified rocker arms from ZZP?
Anyone know of any good articles on installation or can give any advice?
Thanks
Andy
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 10-14-2008, 12:38 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Rocker arm installation?
Nope, never tried them, but I was looking at them myself.
I wonder how they would work with custom PCMs and shift points at 6000 rpms. Valve Float?
I also emailed ZZP who said they do have 1.8 and 1.84 ratio rockers for 399.99. I asked why so expensive compared to the 1.9's and they said its because these 1.84's are new and not remachined. They also include pushrods.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-14-2008, 09:28 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Higher ratio rocker arms will have no effect on valve float; that is determined by the spring’s ability to keep the valve on the seat during high rpm operation. Anything above 5800-6000 rpm and the stock springs are borderline; especially with age. If you are considering doing a rocker upgrade and plan on shifts @ 6200, you might as well install a set of Comp Cams 105 springs, retainers, push rods and new valve seals while doing the job. Personally, I would much prefer the CC Pro Magnum shaft mount rockers, to a set of “reworked” stock rockers! In addition, this would eliminate the stock rocker pedestal. BTW, I use CC Pro-Magnum rockers on both of my Z-28’s; one of them shifting above 6800 rpm, and have never had a problem! Of course, I have the other valve train components to support the rpm. Some good tech info below:
http://www.zzperformance.com/grand_p...les1.php?id=53
http://www.zzperformance.com/grand_p...les1.php?id=43
