Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-13-2008, 09:27 PM
Irishdog Irishdog is offline
Straight pipe exhaust
I have a 1992 eagle talon non turbo 4g63. I recently replaced the stock manifold with a stainless header. I have piping from the header to the cat. I am wanting to bypass the cat and just have straight piping all the way back. What are my options for doing so? (i.e. where to obtain piping, how to bypass cat) I'm wanting to do this without spending an obscene amount of money.
Old 10-14-2008, 12:09 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Straight pipe exhaust
Well... You could just take it to a muffler shop and tell them what you want on it and they'll do it. Assuming that you are correct about the no emissions law where your at, they shouldn't be able to give you a problem with it then...
However... If your more of a do it yourselfer, you could pick up the piping at www.extremepsi.com and just make the exhaust yourself. I have gotten plenty of piping from them and it's pretty good quality for a decent price...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-14-2008, 11:39 AM
Will I be needing to buy an exhaust system? How would I bypass the cat?
Old 10-14-2008, 11:44 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
You cut the cat off and put a straight piece of pipe in its place....then either weld the pipe onto the existing exhaust, or clamp it.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-14-2008, 12:14 PM
Could this be used in place of the cat?: http://www.extremepsi.com/store/cust...1&veh=1G%20DSM
Old 10-14-2008, 12:30 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Yes, but a piece of pipe costs around $5, flanges are like $10, assembly (assuming you pay someone to do) maybe $15-$20. Still comes out a lot cheaper than buying a test pipe like that.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-14-2008, 01:05 PM
Geez... I was talking more of just the standard piping so you can do a whole exhaust yourself or have someone else do it that knows how to... That thing is expensive for a little piece of pipe...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-14-2008, 02:06 PM
david-b's Avatar
Dave is THAT guy
True to that too. You can goto Pepboys and buy lengths of pipe for pretty cheap. I made my custom downpipe for about $10 minus the flanges. And all the pieces fit together, they slide in so you just some weld around and nice tight seal.
75 Monte Carlo
Old 10-14-2008, 02:50 PM
You could cut your stock cat off, flanges and everything, that way you just have a missing section of piping there. And we sell straight pieces of piping at advance. You just need to measure your factory piping after you cut it to get the outside diameter. Then buy a piece of straight pipe with the same inside diameter, and slip fit it in place of the missing section, then clamp or weld it on. Its not hard at all.
Caleb
vanilla gorilla
Old 10-14-2008, 07:14 PM
Ok. So all I'm wanting to do is get rid of the cat. What kind of clamps can I use that won't require any welding?
Old 10-16-2008, 11:00 PM
They're called exhaust clamps which can be found at any autoparts store. Advance Auto for example.
Caleb
vanilla gorilla
Old 10-21-2008, 01:25 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Why bother on an N/A car? All it will do is increase emissions and sound like a buzzy Honda. No real power to be had.
Kris
2012 Genesis Coupe 2.0t
Old 10-21-2008, 02:00 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You may gain a little bit of power on the top end but you will loose a good bit of power in the low to mid range.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-22-2008, 12:46 AM
Lol, I cut the cat off my civic. I didnt do it for performance reasons. I did it because I needed $100, and plus I wanted to make it sound ricier
Caleb
vanilla gorilla
Old 10-22-2008, 01:44 AM
steviek's Avatar
steviek steviek is offline
lol and ill bet you succeeded
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
