Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 10-13-2008, 08:07 PM
traxxasman traxxasman is offline
check engine light
i've got a 95 z26 with an engine light on and when i was about to plug in the good ole paper clip i noticed the obd port only had the ground wire and serial data wire hooked up. Is this normal? If so, how am i to get the engine code without having to take it in?
Old 06-18-2011, 04:49 PM
mhr430's Avatar
mhr430 mhr430 is offline
Re: check engine light
You say only two wires, ground and serial data but there are several possible locations for serial data and it's possible to have more than one even though I do understand that you only have one. What positions are your wires located at?
I'm sure that you're talking about using a paperclip on terminals A and B.
Old 06-19-2011, 11:10 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If no A and B pins it will require a OBD1 engine capable scanner to get codes.
94- 1/2 to 95 was a change over years. From old OBD 1 to OBD 11
MT
Old 06-19-2011, 12:22 PM
Scrapper Scrapper is offline
AF Premium User
just for kicks take neg cable off for about 10 to 15 mins and hook it back up see if light goes out? or take it by autozone and see what they come up with it's free and if they try to give you a key tell them you don't no how to do this. by the way is it missing or anything?
