Old 10-13-2008, 06:23 PM
jdanforth jdanforth is offline
soft brake pedal
i have a 1997 chevy silverado z71 package.i have just put all new drums,rotors,shoes,pads,and calipers on it.my problem is the brake pedal still feels spongy.half to 3/4 play in the pedal.any ideas????
Old 10-13-2008, 09:52 PM
bigbadram51 bigbadram51 is offline
Re: soft brake pedal
replacing the rubber hoses with stainless steel brake lines
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 10-13-2008, 11:02 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
did it feel spongy before repairs? it's a notorious issue, but harmless.
otherwise, got air in lines, bleed the system.
Old 10-14-2008, 05:21 AM
it was spongy when i did the work to it.thought that would correct the problem.i heard that this is a typical problem with theses trucks.
Old 10-14-2008, 07:57 AM
dewaynep dewaynep is offline
Make sure you adjust the rear shoes with the drum on and make sure there is a slight drag on them. That will bring the pedal up a little higher. If you were able to slip the drums on easily and didn't adjust them, that is the problem.
Old 10-14-2008, 07:00 PM
j cAT j cAT is offline
I agree with this..also... the drums must be adjusted to drag slightly on the shoes then back off 3-5 clicks...with all you have done the brake pedal should be high...
air will cause the pedal to have a spongy feel..
Old 10-15-2008, 02:52 PM
thNKS GUYS FOR THE INFO.I ADJUSTED THE REAR SHOES A LITTLE.MADE A WORLD OF DIFFRENCE.I GUESS THESE REAR BRAKES ARE ALITTLE DIFFRENT THEN EARLY 90S TRUCKS.I ADJUSTED THEM UP AND ABOUT WENT THREW THE WINDSHIELD THANKS AGAIN
Old 10-15-2008, 03:04 PM
Schrade Schrade is offline
Through the windshield? YIKES!
Don't wanna' ruin a good windshield do we?
