Help with TJ steering
I need to replace my lower steering shaft on my 97 Wrangler SE 2.5
I can get a heavy duty one from Borgerson for 344.64. I do have oversized tires and I know I should go with this particular one. However, I am broker than a joker. Does anyone know where I can get one of these say to OEM specs where I can save some money on it? I havent been able to find any replacements other than the expensive Borgerson. Thanks guys! -Tom
97 Jeep Wrangler SE 2.5L Things I've repaired: Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount |
