Old 10-12-2008, 02:25 PM
bratt bratt is offline
Post I smell gas by my gas tank
Is it normal for the gas tank to smell like gas all the time?
Is there a breather or something on the top of my gas tank
I can smell gas everytime I stand near my gas tank on my truck
Old 10-12-2008, 04:39 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: I smell gas by my gas tank
No a strong smell speels a leak.
YEAR MAKE AND MODEL?
Good gas cap?
Low or full tank or both?
Dual or singal tank
Have a look underside and see if any wet spots.
Also check fuel lines from tank to engine.
Let us know what you see,
MT
Old 10-12-2008, 10:51 PM
full tank
2000 silverado
single tank
no wet spots
check the hoses around the gas tank yes
Old 10-13-2008, 05:29 AM
farisimo farisimo is offline
Possible the gas cap is defective????
Old 10-13-2008, 08:40 AM
Evansamms Evansamms is offline
I had a bit of a smell only when the tank was full. Turned out, my filler neck had started to rot out. Figured it out when I'd get it mostly after driving into my driveway forward, which made me turn right, so the gas was sloshing more towards teh filler neck. Just something to look at.
Evan
Old 10-13-2008, 08:44 AM
MT-2500's Avatar
AF - Advisor
Originally Posted by bratt
full tank
2000 silverado
single tank
no wet spots
Any check engine lights?
If no wet spots you will need to check tank for holding vacuum and the evap. emission canister and hoses and valves.
Good Luck
MT
Old 10-13-2008, 09:38 AM
j cAT j cAT is offline
If you had a fuel tank problem the check engine light would come on in most cases...It is possible that the cannister above/next to tank is in need of replacement. If you fill up your vehicle and then don't drive very far the expanding gas could saturate the carbon in the cannister.
check the fuel filter fittings also..
I have 2000 sil...and this would not be normal..
Old 10-13-2008, 05:37 PM
[quote=bratt]Is it normal for the gas tank to smell like gas all the time?
I forgot to mention that our vehicles have a fuel filler pipe. this componet is what the gas cap screws into....this pipe is not coated with any rust inhibitors and these do rust out...it is very possible that this filler pipe has pin holes...also check for the copper ground strap to be fully connected to the grounding point as this strap corrodes easily...
