| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Cleaning Dashboard Insulator
Me again with another question on my '89 Civic rebuild. As I mentioned in a previous post, this vehicle is in rough shape and needs tons of work. To avoid future problems down the road (assuming I ever get it finished), I'm doing a very thorough job including removing and painting over every last bit of rust I can find, both inside and out.
The question today regards the interior, specifically the dashboard insulator, which is basically just a piece of molded rubber with a foam backing. I hadn't planned on removing this due to the amount of work involved, but I thought it best because the insulator is quite badly contaminated. There are numerous tears in the rubber, and the lower half is very wet and stinks of mildew. I wanted to remove it not only to clean and repair it, but to check for any rust that might be hiding underneath. All I need to know is what kind of cleaning product would be best for cleaning this thing. I thought of cleaning it twice, first with soap and water and then with rubbing alcohol (or vise versa). I'd rather not use any strong disinfectants because I don't want that smell in the vehicle. Thanks. |
Re: Cleaning Dashboard Insulator
If you're concerned with smell then it sounds like you have it pinned down pretty good. I would suggest the way you want to do it, with the alcohol last. It dries very quickly and will kill most anything. Plus it won't leave a smell.
I must ask though, have you thought about simply buying a new one? |
The insulator isn't torn that bad, it's mostly just dirty. And besides, now that the car is in my care, I intend to make sure it never is allowed to fall into such disrepair again. |
Oh, yeah, I know how that feels. I've insisted on new pars thus my GTC project has been dragging on for three years now.
I think you have the right idea for cleaning it though. |
Wet a towel with warm water and wipe down your dashboard to prepare it for cleaning. Now spray your dashboard with a liquid car cleaner, which can be found at any major automotive store. Use a soft cloth to work the cleaner into the dashboard. Continue over the whole dashboard. Let the area dry before moving on to the next step.
__________________________________________________ ________________ Advertising removed by Moderator Last edited by '97ventureowner; 10-16-2008 at 08:03 AM. |
