Old 10-12-2008, 12:48 PM
davebandiera davebandiera is offline
egr...camshaft sensor problem
I have a 1998 ford windstar Gl...3.8
code 340 came up and replaced part(cam shaft postion sensor)
Reset codes...drove the light came back on....
Code reader reads 340,401
401 =egr
does any one know if they are related in some way....
Old 10-12-2008, 05:14 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: egr...camshaft sensor problem
401 =egr
Dave
Welcome to AFs!
I don't believe the two codes are related. Have you check out the stickies at the top of this forum? There is some good information in those posts.
The p0401 code like you said refers to egr valve with egr flow less than expected. Your egr ports in the intake manifold are probably cloged.
I just had the upper intake off on my 98. I had one port pluged compleatly. I was getting a missfire. Pulling the upper intake isn't too bad of a job to do. Do a search on the forum and you should find posts of other guys doing this job.
I hope this helps.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 10-17-2008, 11:40 AM
CnlK CnlK is offline
When running is there any noise or whine coming from the camshaft synchronizer (the part that the camshaft sensor is mounted to)? The bearings in these are know to fail causing faulty signals from sensor. If so do a search of this forum, there are several threads detailing replacement of synchro. A thorough check of circuit wiring would also be recommended.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
