View Poll Results: How much work do you do on your vehical?
I do 95%. I would change an engie/tranny 11 91.67%
I do some. I would change oil maby brakes 1 8.33%
I do none of my own work and have no interest. 0 0%
I have friends who help me with my vehical. 0 0%
I would do my own work but do not have the time. 0 0%
I would like to do my own work, but my gifts are else where. 0 0%
Voters: 12. You may not vote on this poll
Old 10-12-2008, 12:17 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
%%%**poll**%%%
Poll
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 10-12-2008, 06:24 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Re: %%%**poll**%%%
I do all my work exept for when I need expensive special tools, major electrical problems, and when I need my vehicle back on the road and can't afford costly mistakes.
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 10-13-2008, 12:25 PM
garync1 garync1 is offline
Re: %%%**poll**%%%
I do most all of my work.. Front wheel drives I do limit engine and tranny swaps.. I prefer rear wheel drive when it comes to trans and clutch repairs. Front wheel drives tend to be more of a pain when doing clutch pressure plates swaps.. Now when it comes to trans fluid replacement. I will do pan drops and filter changes but you can't beat the dealer when it comes to staying clean.LOL
You will save a lot doing it yourself..
Old 10-13-2008, 02:31 PM
FordGuy81 FordGuy81 is offline
Re: %%%**poll**%%%
Unless the work requires expensive equipment, I do most of my own work. Changing a tranny or an engine in a FWD is something I have not done and probably don't want to.
"The fortune you seek is in another cookie"
1999 Ford Windstar LX 3.8L
1994 Ford Ranger XLT S/C 4x4 4.0L/Twin Stick
Old 10-13-2008, 08:39 PM
Re: %%%**poll**%%%
Changing trannies and engines on FWD isn't that bad.....just different. Once you do one you'll want to do more! Well....maybe LOL
SW MN
Old 10-27-2008, 09:29 AM
helmdoggie helmdoggie is offline
Re: %%%**poll**%%%
I will do most of the work on my cars if I know what it is. Sometimes I won't even if I know what it is. Case in point I had a O2 sensor go out in my 96 lumina, the one that is before the catalytic converter. I got the part and put the car up and decided that since I literally only had about a half of an inch to work that I would call around and see how much it would cost me. I had midas quote me 2 hours labor and they would use my part but not warrenty it. I also found a coupon for twenty five dollars off so I went with it and let them do it. I dropped my car off in the morning and went back to check on it before I went to work in the afternoon. I felt so bad for the guy he had been working on it since I had dropped it off and still no luck. To make a long story short when I picked the car up the next moring he said it took him eight total hours to get the job done. It cost me about 100 for the labor. I wouldn't have been able to do this job laying on the ground. I later found out that GM makes a special o2 wrench just for this car. Sometimes you have to have the right equipment to do a job, and the dealers usually have the right tools which is a bunch of crap but such is life.
Old 10-27-2008, 04:54 PM
Re: %%%**poll**%%%
LOL!!! Well to be honest if I started with changing FWD engines and tranny's I may not think it was so bad but the first engine and trans I ever removed was in my old 1971 VW SB when I modified it back in 1988. Rebuilt it and all.. Removed both engine and trans.. Took me less than hour to remove both.. But I had removed bug engines before but not the trans so you could say I already knew what to do... Second engine and trans I did was in an 1987 BMW 325i again BMW has rear wheel drive and it was easy.. OK I could keep going with my RX7 that i had which was easy as well... Then in 1990 I changed a clutch in a 1980's something Nissan sentra..After that I said the hell with front wheel drives.LOL No Its not bad it just takes so much time compared to RWD cars..Plus it so dang tight to move stuff around.. Not to mention the ones you have to drop the sub frame along with the suspension. I do think however Camero's which are RWD you have to remove the suspension and sub-frame to drop the trans and motor. Or at least from what i was told.. Just my 2 cents.. Take care..
Just when you think you are done. Your not!! Clean the tools. Then you are done.
Nothing impresses a single mom better than a single dad who drives a minivan.Just kidding
