Old 10-11-2008, 11:19 PM
camarokidrs camarokidrs is offline
Arrow injector flush
So i have tried twice to flush out my injector,the first time i tried tapping in at the fuel filter and turning pump off,of course this is being done with the injector flush machine,proceeded to start car and had a crank no start.
The second time i tried to do the flush i tapped in through the regulator quick disconnect and blocked off return line then shut off pump,proceeded to start car and had another crank no start,has any one ever done a successful injector service,and if so how is it done?????
Old 10-12-2008, 06:04 PM
Blue Bowtie's Avatar
Registered Offender
Re: injector flush
Successful? Yes. Remove the injectors, box them up, and send them off to an injector cleaning service.
Old 10-14-2008, 08:24 AM
dewaynep dewaynep is offline
Re: injector flush
How did you shut off the pump? Did you pull the fuse or relay? If so, that fuse or relay also runs the injectors. You need to pull the electrical connector to the pump that is by the back of the fuel tank.
Old 10-15-2008, 09:55 PM
Re: injector flush
i shut off the pump by disconnecting the electrical connector at the pump
Old 10-20-2008, 04:20 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: injector flush
The pump and injectors share a fuse and probably the relay, remove either and you lose power to the injectors.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-20-2008, 05:54 PM
Schrade Schrade is offline
Re: injector flush
There's some small screens in the fuel inlet to each injector. They can be removed and cleaned, and it's a tedious task.
There's a few pics in this thread somewhere; I can't link the pics; I'm banned.
http://forums.corvetteforum.com/show....php?t=2033363
