Old 03-16-2003, 12:20 PM
AlwaysMovin AlwaysMovin is offline
Question Making a 4th Gen. Turbo kit?
I posted this in the turbo forum, but no answer so I figured I would ask here:
"So whats the big deal with building your own turbo kit for a 4th gen CRX or Civic? Other than experience you gain it seems that most of the home built turbo kits turn out to be most expensive then if they were purchased from like F-max, GReddy..."
Any thoughts?
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 03-16-2003, 12:22 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
i have always heard buying your own kit not a pre made kit that it is cheaper, but i would mess it up, so i'll just buy greedy
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 03-16-2003, 05:05 PM
91zc 91zc is offline
Alot of times when making your own kit you tend to purchase all the nice parts and it ends up more than a pre-made kit because most pre-made kits don't have all top of the line parts or are missing some parts...ie greddy The greddy kits don't come with an intercooler and therefore you will have to source one.
91 civic 4dr
b16a
14.8@94
Old 03-16-2003, 06:04 PM
91civichatchbacksi 91civichatchbacksi is offline
www.homemadeturbo.com
this is a v ery informative site on how to go about building your own d16 based turbo ..links and other useful information will be available...
i am in the process of building mine aswell..i just got an airreasearch turbo from the junkyard for 50 bucks...so im on my way to boost and a bunch of other things...
Old 03-16-2003, 06:39 PM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
Air Research makes REALY nice turbos! How do i know? They cotracted Mercedes benz, and mercedes benz only uses the top notch parts SUCH AS Bosch<----- :ylsuper I presume you got it off a mercedes SLK or something mercedes right? If so I hope you had the common sense to grab more than just the turbo, like the bosch fuel filter and bosch fuel pump and the bosch injector controller... How do I know all this? Because I have a mercedes 5 cyl turbo diesel being built in my back yard as we speak! Should be swaped in on friday! Only makes 140 stock and it only revs to 2500 Rpm's stock. My dad bought a brand new engine and built the piss out of it but left that turbo (He said they dont get much better than Air Research) We are lookin at about 180 Hp and somewere in the ballpark of 900 Ft lbs of tq. This ought to be interesting!
Old 03-16-2003, 08:22 PM
civic turbo setup
to answer your previous question ...NO .... i got it off a turbo Saab...and the set up i have is going to consist of the following
apexi -s-afc
mitsubishi 450cc injectors
2nd gen mitsu blow off valve
hf exhaust manifold
adapter plate ( fits between hf manifold and turbo )
intercooler ( from a saab or mitsu or anything i can get my hands on thats cheap)
and if i have forgoten anything i will update you later.... but for the most par you have several web sites that can help with the custom set up...
also..you can use a turbo from any late model vovlo- i beleive its called a kkk turbo - and a 2nd gen turbo from an eclipse or eagle talon ...but for the most part the vovlos and the saab's have the best turbos aside from the mitsu..if you can find one at the junkyard....easy to remove and easy to check for shaft play and cracks in the housing ....
here are the links
www.homemadeturbo.com ( for turbo set ups )
www.theoldone.com ( porting and polishing tips ) \
http://www.4thgenerationcivic.com/how-to's/How-To's.htm
Old 03-16-2003, 08:36 PM
Banned
Use a turbo off a 85 Mersedes SLK 5 cyl turbo diesel! You wont be sorry! Trusy me on this one... If it make 8 Psi @ 2500 Rpms imagine what it can do @ 5K... that thing can run 12 lbs of boost @4500 with no problems!
Old 03-16-2003, 08:56 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
with the "homemade kit" you get to put in or take out whatever parts you need or want if you go with a greddy kit lets, say but want a blitz BOV then you wasted money on the greddy BOV, so the homemade kit is easily altered to fit your needs.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-16-2003, 09:49 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
I'd buy the Drag 3 kit........ or one from Jon at the drop shop
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 03-16-2003, 09:54 PM
85 mercede's slk turbo????
well i wast aware of this turbo off of that particular car..i will look into ..how ever ZC with stock internals isnt really good for more than 8 psi of boost ..after that expect to break a rod or 2...these engines are onl y good for 8,000 rpm ( 200 hp at the wheels) and i dont plan on boosting more than 7 psi ..just to be safe...
if you think about it, each pound of boost translates to 10 hp....so with 7 psi ( 70 hp ) plus the stock 130 ( give or take ) im looking at about 200hp ....( not at the wheels )
what do you guys think of that set up..i just want some feedback and 1 or 2 opinions...
Apexi S-AFC ( 200 bucks )
auto meter boost gage/ air to fuel gauge (100 bucks )
450 cc injectors ( free )
AirResearch Turbo From a Saab ( 50 bucks )
Hf manifold from a civic (20 bucks )
volvo side intercooler..( will upgarde later for one thats bigger..) 40 bucks
custom piping ...whatever it costs to buy..i will fabricate charge pipes at school in my welding class...
so no more than 500 bucks give or take will i spend on this project...no bad...hope all turns out.....( fingers crossed )
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
