Old 10-11-2008, 04:17 PM
izigara izigara is offline
93 Astro; Fuel , Air mixture? or other problem?
Wife drives a 93 Chevy Astrovan , 150k Vin# Z .Starts and idles great. Problem occurs when put in gear it runs good till it gets about 25-30 mph then motor seems to lose power.almost as if it is starved for gas. it acts almost like the olders cars would when the choke would stick on them but this has a throtle body with no choke. What leads me to think fuel air mixture is no matter how far i press the gas pedal it still doesnt pick up rpm's. Ive replaced the fuel filter and dist cap and rotor , and fuel pump was replaced last year.... just wondering where i should go next... thank you for your time with any answers you might could give me.
Old 10-11-2008, 06:12 PM
94&92Astro 94&92Astro is offline
Re: 93 Astro; Fuel , Air mixture? or other problem?
Originally Posted by izigara
Wife drives a 93 Chevy Astrovan , Starts and idles great. Problem occurs when put in gear it runs good till it gets about 25-30 mph then motor seems to lose power.almost as if it is starved for gas. it acts almost like the olders cars would when the choke would stick on them but this has a throtle body with no choke. What leads me to think fuel air mixture is no matter how far i press the gas pedal it still doesnt pick up rpm's. Ive replaced the fuel filter and dist cap and rotor , and fuel pump was replaced last year.... just wondering where i should go next... thank you for your time with any answers you might could give me.
When I had the bad pump changed in my 94 the replacement had a small hose that attached the actual pump to the housing that fit on top of the gas tank--anyway the aftermarket hose installed in that pump deteriorated causing the same problems you describe-----I had my head in that thing for three weeks tearing parts off of it left and right before I stumbled upon this issue---The fix was just to buy a pc of quality fuel line the same size, attach with clamps and reinstall the pump--after that it roared down the road once again--something I was begining to think I would never see again... Might not be you problem but it happened to my throttlebody it could happen to yours!
Old 10-18-2008, 10:32 AM
Stonedsurfer Stonedsurfer is offline
Post Re: 93 Astro; Fuel , Air mixture? or other problem?
My wifes van had the same problem.... would start and idle great..... revs up great..... but once in gear and going about 25-30 mph would bog down and die.... like you say it acted like it was starving for gas.... let it sit about 5 minutes it would restart but would die if driven past those speeds...very frustrating..... finally gave up in my searching due to limited vehicle downtime... took it to the chevy dealer and the took tech 3 hrs to trace prob to spyder(spider) fuel injection system.... asked why it was quitting under higher speeds but worked under 25?? He didnt know,but everthing else tested good and spider was faulting out..... I replaced it myself and had no other problems with it since but it wasnt cheap and bought my replacement from AZ.... only problem I had was the van kept giving code for bad egr (code 32 i think) and I replaced that before replacing the spider,it still shows the egr code but we ignore it,tech says its working to specs and has a kleen screen gasket.... hope this may help you because our van lost power and died pretty much the same way yours is ...
Old 10-18-2008, 03:41 PM
A 1993 Model doesn't have a spider fuel injection system. Fuel injection was introduced on a limited basis in 1994... Before that it was TBI (throttle boby injection) which operated at much lower pressure (65 vs 12 psi) if I remember correctly.
Old 10-18-2008, 04:30 PM
brcidd's Avatar
brcidd brcidd is offline
Ahh the high output engines were available in '93 and prior-along with the "Z" engines- they all went to high output-- Vin "W" engines in '94 and beyond..So it is possible.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-18-2008, 06:22 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Vin W CPI motors were available 92-94.
However, he says in Post #1 that it's a Vin Z, or TBI motor.
Old 10-18-2008, 07:11 PM
I stand corrected Leeann94astro is right on both counts--however as she states a spyder assemb not an issue on a TBI.
