Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Old 10-11-2008, 12:10 PM
68ragtop 68ragtop is offline
wierd RPM issue with a 3.0 Fuel pump?
Hey guys, workign on my mother-in-laws 2001 3.0 V6. The car won't rev over 4K & can't get it past 40MPH. REminds me of a rev limiter in a gas power golf cart. Any extra gas pedal does nothing. It is setting codes for a lean fuel condition on both 1&2 banks. TPS seems fine, & fuel pressure sits right at 40psi. Are these supposed to be closer to 60PSI I have no clue.
I can hold the accelorater to the floor in park & it stops at 4K, not sure if thats part of the problem, of if these have a 4K rev limiter when its in park?
Any ideas?
Old 10-11-2008, 02:54 PM
Re: wierd RPM issue with a 3.0 Fuel pump?
I got it. It was the MAFS
Thanks for checking in.
Old 11-06-2014, 12:43 PM
wraith05 wraith05 is offline
My car has the exact same problem I already switched out the MAF and no go. The scanner shows that it has multiple miss-fires so they said it was a bad ignition module but to switch both to be safe. Both ignition modules have been change and still the same problem. I was thinking it might the fuel pump as well but my car has good fuel pressure. Now the only thing I can think of is problems with the torque converter? I read a while back that the torque converter in these cars engage at 3000 rpm and that's where the rpms stop, any ideads?
Old 11-06-2014, 02:41 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
did you change the plugs and your plug wires?
Old 11-06-2014, 07:55 PM
I switched the plugs but not the wires.
Old 11-07-2014, 05:01 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Please post what code numbers you are getting. I'm thinking that one of your transmission's speed sensors (input or output) may be bad. Either one might cause the 4000 RPM/40MPH limitation. I would try unplugging one of the speed sensors at a time and going for a drive. The one that doesn't make any noticeable difference during the drive while being unplugged is the bad sensor. Either sensor costs around $20 so it would be a relatively cheap fix.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 11-08-2014, 07:20 PM
I found the problem it was a clogged catalytic converter, thanks for the help
